My hp pavilion entertainment pc has power but nothing showing on the screen , plus when the pc is first turned on the fan comes on for a few seconds then goes off again . I've tried turning it off and putting it on again several tiimes with no success .
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Posted on Sep 18, 2010
How do i fix my LCD?
I have got a hp pavilion dv5000, when I turn on it the screen goes blank.
Power led glows, I hear for a few time the fan, disk led flashes intermittently and also I feel that the DVD player tries to load.
If I try to click on caps lock or num lock, leds don't respond to commands. I tried the hard reset pressing the power button for 30 seconds with the battery and the power removed. Nothing to be done by connecting an external monitor....
Thank you
Jun 11, 2013 | HP Pavilion dv1000 Notebook
HP Pavilion Entertainment PC Laptop DV2000
when you say some times it keeps going does this mean the unit turns off ??,,,,this model has the gpu problem,,,dry solder joint of the graphics card, of which you can have the board repaired or replace the board
Oct 06, 2012 | HP Pavilion Computers & Internet
I have an HP Pavilion dv7-1130 Entertainment Laptop, and as of recently, when I try to turn it on, the lights around the keyboard power on and the fan runs, then the fan stops and the lights stay on. No...
With an extensive use of the notebook,
some times notebook would store some static charges which
indeed will stop the notebook from powering up or charging
the battery. The procedure to remove this static charges from
the notebook is known as power drain. Performing a power
drain procedure will not effect any personal data or delete
any pictures from the hard drive on your notebook.
I recommend you use Power Drain procedure by following these
steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Dec 12, 2010 | HP Pavilion dv7-1130us laptop
I have an HP Paviion dv9008nr Entertainment -black screen at boot
Unseat and reseat the memory one stick at a time in each slot on at a time. After each reseat of the memory, turn on the laptop and see if you get video. If you still don't get video, go ahead and take out the hard drive and the dvd drive.
Then try turning on the laptop, if you still don't get video then the motherboard is bad and you'll need to get it replaced.
Apr 15, 2010 | HP Pavilion dv9008nr Notebook
My HP dv9208nr laptop screen is black after I power it on.
Hi:
I am sorry to tell you that this series of HP laptops has a known problem with the video chip on the motherboard. There are thousands of complaints to HP about the DV9000 seriies laptop, and yours has the same sympoms that others have reported. HP extended the warranty on some, but most people lost their shirts. There are a few people who have had mixed success in repairing the motherboards, but often they have to get replaced. If you did a google search on yor laptop problem, you will find lots of info.
The bottom line is that your laptop is expensive to fix, and it is a known problem!
Feb 03, 2010 | HP Pavilion dv9208nr Turion 64 X2 DC TL-50...
My lab top when restarted it beats 3 times, screen blank
Nothing to worry, Open your laptop from the back side.Remove the RAM  and reinsert it.
Your system will work fine.
Rate this solution.
Dec 27, 2009 | HP Pavilion dv9700t Notebook PC
My laptop won't power up
This is usually caused by the fan not spinning up fast enough, which has been fixed by HP. you need to flash the bios to the lastest version. If you email me the model number i can send you a link.
fixya <at> techiejon.com
Jon
TechieJon
Aug 29, 2009 | HP Pavilion dv6000z Notebook
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
