Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 probably software conflict
My 5150 stopped working at start up. Thought it was PS or Mobo issue. Both are fine so it seems to be a software conflict of some type. I can get into safe mode but cant do much of course! I used system restore to the earliest date listed with no results. Called dell support and was told that the know what to do but since I am out of warranty by a couple of months it would cost me 200.00 for a year of support just to fix this issue.
Anybody have an idea of what dell would have told me?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 50 Answers
You will need to get hold of a full copy of XP off of a friend, as the copy that prob came with your pc will judt format your pc and start again. Dont worry about codes as your should find one at the side of your pc. you just need to make sure you get the right copy i.e. xp home or Pro.
When you have the disk put it into the pc then reboot, your PC should be set up to boot from CD if it is you will be asked to press any key to boot from CD, if not then let me know. you will now get a nice blue install screen up and a few options just carry on (dont select the console recovery as you theres an easyer way). now your PC will start looking for copys of XP installed on your pc, this is where your want to select restore XP (r button).
this will now copy over your old copy of XP but this will mean that you will not loss any programs or files.
Please be careful if your get up the options to format your PC then you will loss every thing. just reboot and do it all again. :)
Hope this helps. If you get stuck let me know,
you will now need to do a full
Posted on May 14, 2008
Dell 5150 won't load drivers
Hi try going to control panel, system, hard ware and then device manager. If you have any driver issues, your device will be highlighted by a yellow ? With your driver CD in drive, click the + sign and right click the device with the problem, select update driver, follow instructions and select install driver from disk. Hope this helps
Jul 16, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
For having my new "ADSL" box installed, i need to connect it on my DELL 5150 dimension via an ethernet cable. It doesn't work. It seems that i have no ethernet drivers on my Dell PC. Is it possible ?
Hi,U need check in the BIOS Ethernet is enable ...? than check in Device manager if it is Yellow mark in Ethernet icon if it there u need uninstall the drivers and reinstall.
Feb 08, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 will not start!
This is related to Hardware.
There might be a lose Ram of data cable connection on Motherboard.
This type of issue is also seen when the there is dust accumulation on Process Fan and CPU fan resulting in over heating.
This might also be due to malfunction of a motherboard.
The third reason could be that SMPS his not working.
Nov 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 CD door closes quickly.
If an application is attempting to access the CD drive, the door will close. Put the CD in first and then launch the application.
Also possible a problem with the eject/load mechnism in the CD drive.
Oct 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Flashing Orange light, computer wont boot
Below is the link to the NoPower, No POST, No Video troubleshooting.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=&treeid=011360B8243248349C306481A954B356&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=en&toggle=&dl=falseFollow all the steps without skipping any and if there is no hardware failure,this should definitely resolve your issue.
Hope this helps. Please rateyour feedback!
Thanks,
VJ
Mar 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Noisy fan - ~Dell Dimension 5150 (3 years old)
This issue is discussed here: Click Here
As for the fan check it inside the pc sounds like you may be missing a screw
Mar 07, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Feb 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Start up fault
I'm not an expert at this!!
I looked up Dell Tech Faults on another pc.
Disconnect power and press on button to discharge pc. Remove side panel. Remove all USB port cables including hubs. Remove memory from the CRIMMS. Reconnect memory. Reconnect usb's. Replace panel and power cord. You can always connect to Delle Tech Support - doesn't cost.
For some reason only known to anoraks or rocket scientists--- this works and pc is restored to former glory.
Hope this works for you too.
rgds
Stuart C
Dec 13, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
PNY memory
Hi
Dell Dimension 5150 supports DDR2 400MHz (PC2-3200) and DDR2 533MHz (PC2-4300) unbuffered SDRAM Memory (DIMM). You may install a total of four DIMMs in capacities of 256MB, 512MB, or 1GB. The maximum memory supported is 4GB.
From your query, I think the obvious question is; What is specification of the PNY DIMM and/or does the PNY DIMM meet the requirements for Dimension 5150?
Check for memory configuration and installation procedures for Dimension 5150 - http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1364711
The Chipset used on Dimension 5150 is Intel 945G Express. I am not aware of specific compatibility issues regarding the Intel 945G and PNY Memory modules. However, there may really be known issues that I am not aware of.
To proceed, ensure that the PNY Memory is compatible with Dimension 5150. If not, install compatible (memory type, speed, capacity) DIMMs.
Let me know if further help is needed.
Mike
Jun 05, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
121 people viewed this question
Alun Cox
