Question about Coby MP-C7085 MP3 Player
Off and on switch
The switch will not engage. the hold button is off.
I HAVE THE EXACT SAME PROBLEM.
Posted on May 20, 2008
Remote lighting via 12volt reciever and 240volt 10A relay with a 12 volt coil
You need a holding contact to keep the coil circuit engaged.
The coil on the 240v relay drops because it is wired through a normally closed contact. Wire it through the opposite contact, NO - normally open.
This contact will close when you push button and keep the coil engaged.
Dec 18, 2017 | Electrical Supplies
The air switch on my whirlpool tub will not toggle, i must hold the button in to keep motor running.
What you are experiencing when you push the Air Button down and it engages the BATH PUMP but when you release the the Air Button is a bad Air Switch in the BATH PUMP.
When you push the air button down it sends a column of air to move a small switch in the BATH PUMP. When the switch in the BATH PUMP is bad it will not engage.
What you need is a new Air Switch model TBS-339.
Rod
US Parts Center
888-521-6183
Feb 28, 2013 | Home
Fan push controls won't stay engaged
Replace the pushbutton switches.
Jan 17, 2018 | Dryers
After battery ran low, now radio will not power up with power button.
Make sure you don't have the HOLD button engaged. This button is what keeps your station buttons, power, etc., from accidently switching when you bump it.
This button is found on the top right hand side of the radio if you are looking down on the radio with the clock display facing you.
If the button is showing the red painted mark, you have the HOLD button engaged. Switch it off, and then press the Power button to turn on the radio.
Sep 23, 2010 | Sony Walkman SRF-M37V AM/FM/Weather/TV...
Kenmore Dryer (Model #11073952101) starts, but WON'T stay ON
your motor maybe going out. theres a switch on the motor that starts it . on most models the start switch is built into the motor. however some models the switch can be replaced by itself.
Aug 30, 2009 | Kenmore 73952 Gas Dryer
I did not follow directions on self-cleaning and now stove is loc
Since the door is open and the lock is engaged, you will need to hold the "door closed" switch in located in the top left door opening. Push and hold the switch in, push the clean button, set the time at 3:00 hours, keep holding the switch in for 20 seconds, then push cancel button. The motorized locking mechanism should disengage. Then, you can release the switch. Hope this helps.
Dec 06, 2008 | Frigidaire FEF352 Electric Kitchen Range
Sansa e260
1)Shut down the player.
2) Make sure the hold switch is engaged.
3) Hold down Reset and Menu buttons until system starts up in recovery mode.
Apr 07, 2008 | SanDisk Sansa e260 MP3 Player
My oven door will not close it has a lock button showing can't cancel
make and model??
is not actuallly physically closing??? perhaps the lock/ latch has partially engaged prevetning door from closing, and with the door oopen it cannot do anything for safety reasons. can you see a door /light switch thtyou can depress by hand??? if so push and hold it in the light should go out, and at this point continue to hold in switch and try starting a self clean cycle ( dont worry it wont actually start cleaning right away)it then should activet the latch assy to fully engage and suppoedly lock door, still depressing the button then press thecancel button and the latch should return to the normal resting position and you can close the door
Apr 01, 2008 | Kitchen Ranges
Kenmore Dryer
The start button works like a push-on switch that engages the timer switch. It's all one unit. It isn't engaging because the internal lever the engages the switch is either broken or worn out. The start timer/switch will need to be replaced.
Jul 09, 2007 | Fisher and Paykel DG05 Gas Dryer
Coby MP-C7085 MP3 Player Logo
14 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
