How can I reboot my acer M661? The power light is on but will not boot.
  • Computers & ... Master
  • 5,660 Answers
From your brief diagnosis it sounds like a Power Supply problem. Weak voltage power rail.
1) ALL the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts.
Depends on what Processor it is.
The Acer M661 has a variety of Processors that can be installed from the factory. (Acer)
A) Intel Core2 Duo
B) Intel Core2 Quad
http://support.acer.com/acerpanam/desktop/0000/Acer/VeritonM661/VeritonM661sp2.shtml
Depending on which Core2 Duo, or Core2 Quad, the Processor could use up to 65 Watts, or 105 Watts.
http://en.wikipedia.org/wiki/List_of_intel_core_2_microprocessors
(I don't think Acer would offer one of the Intel Core2 Extreme processors. Depending on the model, they can use up to 150 Watts)
With a Power Supply that is weak, it can produce enough power to turn on LED lights, and perhaps spin fans, but not enough power to turn the Processor on.
The M661 comes with a generic ATX 300 Watt power supply.
Acer is known to use low quality power supply's.
Solution would be to use a KNOWN to be good, Compatible power supply for a test.
[Compatible:
Has to have the correct form factor for the Power Supply.
It's an ATX form factor.
The size, and shape of the case of the Power Supply, is it's Form Factor.
ATX power supply form factor is approximately 6 inches Long, 6 inches Wide, and 3-1/2 inches Tall.
Has to have the correct power cables.
1) I don't have access to information for the motherboard, used in the Acer M661.
Can't tell you if a 20-pin ATX main power cable is used, or a 24-pin ATX main power cable.
A cursory glance inside your computer will net this info.
My guess would be a 24-pin ATX main power cable.
Example;
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
2) Has to have a 4-pin ATX +12 Volt power cable, or an 8-pin EPS +12 Volt power cable,
A) 4-pin +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
B) 8-pin EPS +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
The reason I made the above statements, is that you may have a working power supply, in a computer sitting around no longer in use. You could borrow this power supply for a test unit.
Posted on Sep 12, 2010
  • 137 Answers
1. remove the battery
2. Press power button now. keep power button pressed for 2 mins
3. Reseat the battery.
see if it works !.
Happy Computing. !!!
Else please aloberate.
What pci communications controller acer m661 drivers
if you have problem with installed driver. you can use driver pack solution to find any driver on your computer. it easy to results your problem. good luck my friend.
this mian board support windows xp & vista
you can download all drivers for m661 from this link below.
http://www.acer.co.th/ac/th/th/content/drivers
May 07, 2014 | Acer Veriton M661 PC Desktop
How to enter acer veriton m661 boot menu
On most PCs you need to press F8 continuosly wheen first starting your computer, If that does not work try you Del key
Apr 02, 2014 | Acer Veriton Computers & Internet
Power indicator light is on but will not run, fan turns off and on randomly
It sounds like the power supply in your computer has gone bad. Thats the box you plug the power cable into in the back of the computer. It looks like you should be able to get a standard ATX power supply and replace it.. or have someone do it for you. You can get one for no more than $50, sometimes less.
Dec 25, 2012 | Acer Veriton M661 PC Desktop
I would suspect a PSU, how old is the machine? Check the CMOS battery, reseat the Memory mods.
Q9550 With Acer EQ35M MOBO
It is very likely that you simply do not have the right BIOS setup for the new processor. You will likely have to flash all your bios to get the new processor to both be recognized and to be able to recognize components on the motherboard. That is quite a jump in technology and it may be that the motherboard simply will not support the new processor period. In that case, be VERY careful buying your new board and make sure it specifically supports your processor. Sorry I could not be more help!
May 22, 2012 | Acer Veriton M661 PC Desktop
What type of motherboard do I need for a acer veriton m661
you need m.b intel Q35/31 / G41 intel chipset mini m.b
  • dimention around
    Height: 14.4"
  • Width: 7.1"
  • Depth: 17.4"
    if use the same case
  • Jan 04, 2012 | Acer Veriton M661 PC Desktop
    Black screen after turn on
    That "Blue Screen" is also known as "Blue screen of Death".
    The problem is due driver compatibilty or unstablity.
    Try to boot your system to "Safe Boot" by pressing F8 during startup.
    Select "Last know good Configuration that works"
    Check if it can take you to desktop.
    Unstalled the wi-fi driver and reboot.
    If the above procedure fails, again
    Select "Safe boot"
    Now create a restore point  and download the lastest version of your WI-Fi driver and installed.
    This should work fine.
    Otherwise Backup all your important data from your hard drive (mainly opearting system file installed drive usually C:\) and go for a new Installation.
    Dec 28, 2009 | Acer Aspire One PC Notebook
    My acer veriton m661 desktop--i cannot set the time,checksum corrupt,possibly flashed with wrong acer bios-acer europe-any fix??
    Examine the setup options to see if there's a failsafe mode or a BIOS reset/restore. Otherwise contact Acer tech support to see if they can provide a BIOS reset. You may have to send it to them. Older motherboards had BIOS on a 28-pin socketed chip called an EPROM. These could be ordered from various suppliers with upgrades, etc. I have not seen these in use lately.
    Dec 12, 2009 | Acer Veriton M661 PC Desktop
    Cant find pci serial port for acer m661
    Please see illustration below, hope this helps.
    Nov 25, 2009 | Acer Veriton M661 PC Desktop
    Acer aspire 5050 can't turn it on
    If you dont see any green lights and you dont hear any boot up sounds ( hd, fans, etc) try to take out battery and just plug in the AC adapter to a known good power outlet. Make sure your power plug is good too. If you hear boot-up sounds, see green lights but no display then toggle on the "fn" key and or try on an external monitor.
    Dec 13, 2008 | Acer Aspire 5050-3242 Notebook
    Computers & Internet Logo
    244 people viewed this question
    David Payne
    David Payne
