Question about HP Officejet 5610 All-In-One InkJet Printer
Error message 2349 code 1603 fatal error msi.bufferchm windows xp pro how I fix
5 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: I have a Compaq C751NR
  1. Un-install the printer
  2. Click Start .
  3. Click Settings .
  4. Click Control Panel .
  5. Double-click Add/Remove Programs .
  6. Select HP PSC & Officejet 6.0 and then click Change/Remove .
  7. Follow the instructions that display on the screen.
  8. Disconnect the unit from the computer.
  9. Restart the computer.
Then download and install the drivers from HP's site:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1119598&cc=us&lc=en&dlc=en&product=1119598
The drivers on the cd are probably causing the problem.
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 16, 2008
  • 47 Answers
SOURCE: Fatal error installing HP 3055 all in one
Try download he right software for your OS from HP.com, typically software issue. Be sure to choose the right language for your full software solution, get fatal error when trying to install software with wrong language support.
Posted on Nov 22, 2008
nikeananth
  • 267 Answers
SOURCE: ERROR: -1603 FATAL ERROR DURING INSTALLATION
HI,
This will say the reason and how to overcome it
http://support.microsoft.com/kb/834484
Posted on Oct 01, 2009
OK, here is my debugged/tested solution.
I know your error refers to a different installer MSI file (CIOUM32.msi) but the installation component in your log file (ipm12.A4B24390_80AD_4BAF_B8FD_C670FE0DB586) is identical to the one that was giving me trouble as well (i.e. points to the same service/file). So it is definitely worth a shot to try this solution out as it will only take a few minutes.
My Scenario:
OS: MS Windows XP SP3 [Version 5.1.2600]
Printer: HP LaserJet 3390 (AiO) (Firmware datecode: 20070331)
Printer Connection: Connected via Ethernet with a static IP address
HP Driver Version: v4.0 (hp_LJ3050-3052-3055-3390-3392_Full_Solution_AMWE.exe)
Ran into same error that everyone else is experiencing. (see below)
Now Launching=X:\hpzmsi01.exe -m dot4msi -l XXX -f X:\DIVins??.DAT
Error message received: The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2753.
X:\HPZBDI32.msi failed with return code 1603
MSIInstall() failed with 1603
Exit code=1603
After debugging HP's installation scripts for 2 days, here is the cause & solution I identified to this specific install error. Once I got passed this error, everything installed without error and all functionality was working properly (including scanning!).
BACKGROUND:
Microsoft Installer (MSI) error 1603 is simply a generic "A fatal error occurred during installation" -- see http://msdn.microsoft.com/en-us/library/aa368542(VS.85).aspx. This is basically MSI telling you that something very bad has happened during the installation. In order to get more details, you can turn on MSI debug logging by following this MS Knowledge Base article (http://support.microsoft.com/kb/223300).
The MSI error code 2753 is the code for "The File '<file name>' is not marked for installation.". This error can be triggered by many scenarios, but usually, it has to do with the actual installation script not properly checking for the existence/non-existence of an installation file and then not marking it for either installation/removal. I know this sounds confusing, and it is. If your curious about all the possible causes, just Google for "msi 2753 not marked for installation" and you'll see lots of results which you can peruse for your own enjoyment.
In order to identify what was causing these 2 errors, I enabled debugging for MSI via the aforementioned MS KB article
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
If all goes well, the install should now run without any issues.
Hope this helps since many people (including myself) have spent a lot of time (and HP Support chats) trying to find a workaround for this issue.
If you find this solution helped you out, please feel free to make a small donation to my PayPal ;)
Posted on Oct 30, 2009
Error code 1603
Anonymous,
At the link below is a Microsoft KB Article referencing the Error 1603, the cause and a Resolution.
Error 1603 You receive an error 1603 fatal error occurred during installation...
Thank You,
Dell-Jesse L
DellCares
Dell Social Media and Communities
Jul 19, 2014 | Dell Latitude E6440 BTX Laptop Computer -...
ERROR:-1603 fatal error during
1) Click Start > Run
2) Type msiexec /unreg and press enter and wait until it appears to have
finished.
3) Go back to Start > Run
4) Type msiexec /regserver and press enter.
5) Try to install 'management' again.
Jan 13, 2010 | HP Pavilion DV6700T Notebook PC
I have a Compaq C751NR Notebook that has Windows Vista and am trying to install the Windows Vista disk from the HP Officejet 6310 All-in-One. I keep getting "Fatal Error" error code 2349 and...
  2. Click Start .
  3. Click Settings .
Thanks, Joe
Oct 16, 2008 | HP Computers & Internet
Aug 02, 2008 | HP LaserJet 3050 All-In-One Printer
Error 2753 HP3055
My Scenario:
Exit code=1603
BACKGROUND:
CAUSE:
SOLUTION:
Steps:
Jun 26, 2008 | HP LaserJet 3055 All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
254 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
