Question about Zenith ADR620 CD Player
Dvd stops playing after a few seconds, then a "disc error" message appears on the screen.
  • Zenith Master
  • 11,800 Answers
The laser sensor looses the return signal because either the lens is covered in dust or the head mechanism is faulty and can't follow the tracks accurately enough.
Open the player and clean it thoroughly - use a can of compressed air and a q-tip for the lens and another q-tip for the mechanism - make sure all the cogs and the screw are spotless then oil them very very lightly.
If that doesn't fix it then the damage is too great, you will have to replace the entire mechanism.
Posted on Sep 12, 2010
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
I start playing a DVD Video on my new Sony bdp s360. After a few minutes, the player stops and a message appears on the screen "an error has been detected". At same time the player display shows...
give the lens a clean with a soft cue tip or cotton bud with methalated spirits.should be fine after that,its a reading problem,and even the finest of fur or dust can cause this
Dec 04, 2010 | Sony BDP-S360 DVD Player
DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
No File and Disc Error message
clean dvd first with cd cleaner.. before you change optical lens. lens cannot read data on your disc.
Sep 09, 2009 | Televison & Video
Emerson EWR 20V5
Jan 17, 2009
I posted this Jan 3, 2009 and seem to have a solution.
Similar problem. E4 54037380 Can not record on this disc. Even though it is from the same package of DVD-Rs that I have successfully recorded to previously. Contacted them about 9 months ago without a successful resolution so I am trying again. Unit will play any DVDs, will record and play back DVD-RWs but will not record on my imation DVD-Rs 8X discs that worked fine in the past. Starts to record for a few seconds and then the error message appears (sometimes with slightly different final 4 digits of error number). Other postings have suggested: maybe a firmware update is available (I requested and we will see Emerson's response), trying slower speed discs (I am skeptical since these 8x imation discs in this same package previously worked, and the instructions say 1-16x for DVD-Rs), unplugging the unit for 1/2 hour to reset the unit (did not work), playing the last disc recorded to the end and then trying a new disc (now it recorded for about 30 seconds rather than 10 seconds but then got E4 54043E02 error message, different but still did not work). So I am hoping for something more productive out of Emerson this time.
Update Jan 17,2009. Bought a CD and DVD cleaner disc with the little brushes on it. Cleaned the EWR20V5 per the cleaner instructions and tried to recod on the imation DVD-R 8X that I had used successfully in the past, no luck, same error message. So I bought another brand, maxell DVD-R 4.7GB up to 16X and IT WORKED. The instructions on pg 25 say for DVD-R "up to 16X" may be used but "4X-8X disc is recommended". Go figure, no idea why the 16X worked but they did in this case. So just a suggestion to try other brands. Someone else had suggested that also so I gave it a shot. $8 of new discs and $13 for the cleaner and I've back in business.
Jan 16, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | LG Televison & Video
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Will not playback get error message Please Check Disc
i have a r136 , have you got the dvd discs u need ? i had the wrong format .
eg, dvd+rw needed dvd-rw
if not and there re-recordables they dont work after a few recordings and u need a new disc.
Dec 05, 2007 | Samsung DVD-R130 DVD Recorder
Dvd player died
Did you check the fuse in the power supply? You have to open the box and its very easy to get to. DS
Apr 19, 2007 | Yamaha DVD-S510 DVD Player
Zenith ADR620 CD Player Logo
61 people viewed this question
Top Zenith Audio Players & Recorders Experts
Greg Cann
Greg Cann
xalint1
xalint1
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
