Question about Compaq UPS R3000 XR UPS System
I now live outside the US and brought my compaq ups r3000 xr with me and am having a problem getting a receptacle to plug it into. my electrician needs a part number as he has never seen that type of plug.
  • Compaq Master
  • 11,800 Answers
First of all you should make sure that the UPS is capable of handling the mains voltage from the country you're into now. After that just cut the cable as close as possible to the old mains plug then add a new one - all you need to be sure is which is the ground wire and that is very easy to find out with a simple ohmmeter. When you will go back to the US all you will have to do is to replace the plug.
Posted on Sep 12, 2010
Brand new Frigidaire Electric Dryer gives Error E61. Store brought out another identical dryer with same result. Help please!
The problem is not with the dryer as confirmed by the other identical dryer brought by the dealer. The problem is in the wiring of the receptacle where the dryer is being plugged in as characterized by error code E61 which means the control board is receiving a high voltage. The dryer operates both on 110VAC for the controls including the motor and 220VAC dedicated for the heating circuit. The receptacle must be configured according to the specifications of the dryer. Refer to the diagrams below and configure the receptacle according the plug that came with the dryer. Voltage across L1 and L2 is 220VAC, L1 and Neutral is 110VAC, L2 and Neutral is 110VAC.
Note: You may need the service of a certified electrician for this task.
Jul 13, 2011 | Frigidaire Electric Dryer
Require user and service manual for compaq ups R3000 242705-001
The Compaq R3000 were rebadged APC ups' and so I would suggest looking in the APC website http://www.apc.com/ and select your country and they will be able to help you out ( possibly a download of the manual and software )
Jul 25, 2010 | Compaq UPS R3000 (242705-001) UPS System
Hi, I live in Argentina and I have a kenmore 96093800 Dryer. This Machine has 120/240v and his plug has 4 pins. Two pins are flat, one pin is cilindric, and the fourth pin is en angule. How can I connect...
Are you connecting this Dryer cord to the Dryer or are you looking for a wall plug with this same configuration to plug into. This is a standard double ground configuration and you can buy the wall receptacle at a hardware store. Your house should have 4 wires to this, 2 lines, a neutral, and a ground. As always the recommendation is that you have an electrician install your house receptacle. Your Dryer power cord is something you can install however. The two outside terminals on your dryer 240 volt wiring block are connected to the two outside wires on your power cord. It does not matter which wire goes to which side. Your two inside wires on the power cord are connected like this. One to the middle terminal on your 240 volt dryer terminal block and one is connected to the dryer case itself. Again it does not matter which wire goes to which ground. Make sure all of your connections are tight, as loose terminals eventually burn up. Do Not plug in your dryer power cord until everything is hooked up tight. I actually had a customer plug in his cord and then try to connect the wires to the dryer. The wires arced together and blew the terminals into molten metal which burned this customers hands and face. Do not do and electical repair unless you know what you are doing. On your cord the two straight terminals are line terminals, the round and L shaped terminals are grounds or neutrals. Good Luck, Appliance Specialists
Dec 15, 2009 | Washing Machines
Computer left outside, is it damaged?
If you didn't plug it in wet and you brought it in and gave it a few days to temperize and dry off. No. It shouldn't be damaged. Laptops have to live in all kinds of weather conditions so they have a bit of weather protection built into them.
Your owners manual should show the limits of temperature for operating AND storing your laptop.
Dec 09, 2009 | Compaq Computers & Internet
Compaq UPS R3000 XR Comms cable
Hi Jon,
so we could use this link it as a solution for your problem?
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=3447589&prodSeriesId=255222&lang=en&cc=us
Kind regards,
noris017
Feb 25, 2009 | Compaq UPS R3000 XR UPS System
R3000 DC025052300 unplugged
Right after the rj11 jack where you plug your landline in. You can follow the leads easy from the jack. Opposite side of the processor side.
Jan 30, 2009 | Compaq Presario R3000 Notebook
Compaq Presario R3000 (intel) 2800 Reset 4 or 5 time a day
Kees,
It sounds like you have fried motherboard. If that's the case, you have to get it serviced by a place your manufacturer recommends. Sometimes the cost can be greater than just buying a new laptop, so shop around and see what you can find price-wise.
Please let me know if this helps. Good luck!
Feb 29, 2008 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Black Screen with flashing cursor
Lines are the BGA RAM Or VRAM Needing rework.. This will also cause boot issues on these models. Do you ever see the Compaq Logo? Weve repaired a ton of these and class settlement happened for the R3000's regarding the jacks but we could repair the other issue as well. (As well as install a new jack while its here).. HP's reimbursing for these outside repairs.
Feb 01, 2008 | Compaq Presario R3000 Notebook
Pressario r3000
I have the same problem. I found this blog to be helpful in taking apart a Compaq, also the user manual from Compaq, available here is very complete.
Nov 09, 2007 | Compaq Presario R3000 Notebook
Compaq UPS R3000 XR UPS System Logo
99 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
