Question about Frigidaire Dishwashers
Frigidaire dishwasher Mod # MDB122LBS0 will not drain after use. i replaced pump, drain hose is open. could the problem be in the timer???
SOURCE: dishwasher not draining completely
If you take the toe panels off and look at the motor you will see the discharge anti-siphon tube there with the drain hose attached. That tube is the discharge major restriction point. Be careful not to destroy the anti-siphon valve, by pulling the bale, remove it, a flapper valve. If you can't see through the tube you have found the problem. Punch a screwdriver into it to dislodge the crap and clean it up. Put the anti-siphon valve back in as found and check it out. Be careful, when you remove the tube , water will come out of the pump assembly. If you remove the hose be sure to watch for water there also.
Posted on Jan 12, 2008
futureloginn
  • 734 Answers
SOURCE: Frigidaire Dishwasher won't start
hi there,
as u said that u have already replaced the timer u may also try the following:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Posted on Dec 10, 2008
  • 864 Answers
SOURCE: Water will not drain out of bottom of
Check the input to the drain hose to make sure it is not blocked by something like a cherry pit.  That could cause the water to not drain fully.
Posted on May 20, 2009
  • 10865 Answers
SOURCE: Kenmore portable dishwasher not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Posted on May 28, 2009
  • 220 Answers
SOURCE: Maytag MDB5100AWB Dishwasher not draining
More than likely the filter is clogged,remove the spray arm(there is a threaded cap in the center of the arm twist it to the left,then remove the # 15 or 20 torx(star shaped) screws out of the filter cover(around the edges)The filter is round and runs around the outer edge of the pump housing it lifts right out,clean it and reverse the process.It's the most common issue with not draining on this model.
Posted on Sep 26, 2009
Testimonial: "The solution from TomZS was precisely what I needed to fix my Maytag washer. Thanks a million!"
Hi I have an Bosch SGs43c02gb/35 and it does not drain all of the water out when it has finished the cycle, I have cleaned the filters out which were relatively clean and run it with a dish washer cleaner...
Hello
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
Aug 20, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher draining / emptying of water
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump
Belt
Motor
Timer
Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Oct 27, 2008 | Frigidaire Dishwashers
Dishwasher will not drain
Hello, Following things should be checked properly to see what actually the matter is.
1)Drain Hose It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again. 2)Pump Assembly The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective. Belt It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it. 3)Timer A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor. 4)Motor The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor. 5)Drain Valve and/or Solenoid
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them. Thanks
Jun 17, 2011 | Maytag Dishwashers
Water didnt drain from frigidaire dishwasher model FDB989GFC
Hello!
If your dishwasher does you need to check all this parts:
1. Check sink drain and drain hose for restrictions
The drain hose and recirculation hoses can be responsible for leaks. The drain hose can cause the dishwasher to fail to drain properly. The recirculation hose can be responsible for problems with poor rinsing of dishes.
2. Unjam the motor
3. Unjam the pump
4. Check the drain valve
5. Check the drive belt
6. Test the timer motor
If you have a brand new dishwasher or garbage disposer, check the knock out plug on the garbage disposer.
Dec 02, 2009 | Frigidaire Dishwashers
MY SON'S DISHWASHER WON't drain
Hello there:
Please try these things below my post and click on the links that are available for you ok
I hope that tthis is very helpful for you
best regards michael
Water will not drain from my dishwasher. Investigate these six areas if water will not drain from your dishwasher :
dishwasher_drain-hose.jpg Drain Hose
dishwasher_pump-repair-kit.jpg Pump Assembly
dishwasher_belt.jpg Belt
dishwasher_timer.jpg Timer
dishwasher_motor.jpg Motor
dishwasher_drain-solenoid.jpg Drain Valve and/or Solenoid
Nov 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
My Frigidaire dishwasher doesn't drain completely after it cycles through completely. This is a new dishwasher just installed it a couple days ago.
Drain line/air gap
Pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Timer
Sep 03, 2009 | Frigidaire Dishwashers
The water comes back in the dishwasher after the cycle is done
Actually your dishwasher is not completely draining. There are a few possible reasons for this. I will describe them so you can isolate the problem"
Drain line/air gap
Pump
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Aug 02, 2009 | Frigidaire FDB1502RGC Built-in Dishwasher
Dishwasher always fills to float valve
There are actually several possible causes of your problem. I will briefly describe each in hopes that you can isolate the problem and will then know how to proceed.
Drain line/air gap
Pump
Belt
Motor
Timer
Aug 02, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
My new dishwasher wont drain.
hi there,
1. Drain line/air gap
2. Pump
3. Drain valve and/or solenoid
4. Belt
5. Motor
6. Timer
Drain line/air gap
Pump
Belt
Motor
Timer
problem is surely with one of the above so check and get going...
good luck
thanks for using FixYa
Jan 12, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwasher Not Draining
In many cases the connection were the dishwasher connects to the disposal or sink trap will become stopped up with a build-up from materials from the dishwasher. With the dishwasher turned off disconnect the drain hose from the washer and sink connection. run an object through the connection going to the trap or disposal ( after shutting off power to disposal and clean out build-up. Shouldn't take over 30 min.
Froggman
Jul 22, 2008 | Frigidaire Dishwashers
Dishwashers Logo
41 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
