Question about Sony Handycam DCR-HC42 Mini DV Digital Camcorder
My sony handycam has suddenlky stopped shwing the display..is there any setting that need to be done
    Genius:
  • 1,812 Answers
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to usually be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 12, 2010
2 Suggested Answers
  • 14 Answers
SOURCE: sony handycam vision trv118 displaying c:31:23
This is the most common problem in Sony camcorders of various models.  It is most likely a problem with a rubber bushing on the inside.  It is an easy fix but it is very hard to explain with out pictures.  Here is a link to a GREAT tutorial however, it is written in Japanese.  All you need to do is follow the excellent pictures and this should take care of the problem.  The plastic tube on the inside of the rubber bushing is the most likely cause so just follow the pictures.  He uses a drinking straw to fix this.  Good luck.  This has fixed my camera perfectly!!!!!!!!!  http://d.hatena.ne.jp/tomo_snowbug/20090207/1233989258
Posted on Dec 04, 2010
My SONY handycam 505 touch screen does not respond. What can I do. Is it fixable?
Unfortunately this fault might need more attention as the set must be opened out.
Try to remove battery and reset, dry out by keeping the set warm, clean the display panel of any dirt.
if this wont work the camcorder must be openend and checked on the diplay panel if there is any line stips, the flexible lines being cut or broken. remove and fix connectors, if set was not used for long time put the set ON for several hours.
If this wont work you must contact Sony service to confirm if the display control board is faulty
Aug 23, 2010 | Sony Handycam DCR-DVD505 DVD Camcorder
My Sony handycam optical zoom stopped working
needs to be check by an authorized SONY DEALER.
theres a ribbon connector that needs to be replaced ,or If you drop the camcorder by accident it could be that the ribbon is misplaced, hope it helps , AJ
Oct 23, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
LCD DISPLAY SCROLLS Sony Handycam DCR-SR62
Had the same.after stopped showing anything and the rest was working perfectly. Changed the flex wire connecting camcorder and it's like new. got from the repair shop and did it by miself. Good luck
Meggita
Aug 04, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
There is no playback picture viewing a recording.
if you have the setting to avi it will not show up, you will get sound but know pic just a black screen, try the dvd setting and the the other dv setting.
Dec 03, 2008 | Ulead Videostudio 8 for PC
Sony TRV 245E
I wanna know its model number, is it DCR-TRV245E or some thing else..?
Aug 16, 2008 | Sony Handycam CCD-TR818 Camcorder
Sony Handycam DCR-TRV18E
Firstly you need the remote control that came with your camera (RMT-814).
Switch on your camera to VCR mode. Then on the remote, press the Data Code button (and of course, point the remote towards your camera). This should display the date and time in the bottom left of the screen.
It should display the appropriate date and time for each bit of recorded video.
Hope this helps!
Ron.
Jul 06, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
Problem with importing videos from sony handycam to computer. Can someone help?
let me tell you about importing movie in PC problem. set camera unit on Player mode and select USB straming ON position in camera menu. picture-package will start imorting movie files.
2nd thing is that file size will be realy big. dont know the reason but its fact.
May 27, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
Sony handycam camcorder lcd screen white and no displays
For the "all white screen" in daylight problem, check to make sure the "Nightshot Plus" slider switch is set on "off."
Jan 05, 2008 | Video Cameras
Cant see picture in viewfinder or on screen
Sony handycam dce-dvd 300. I can see the display and set up options but have a black screen otherwise.
Dec 15, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Computer mode
hi follow this steps: Make sure that you have installed the USB driver for the handycam. You can download the drivers from this link: Sony Asia Pacific Support Website--Download Page for HC40E USB Driver for Windows. Connect the handycam to the AC adaptor (the same as putting it on charge). Set the handycam to USB stream mode. (Press P-menu, press MENU, Press EDIT/PLAY, Press USB MODE, Press USB Stream.) Set the tape at the point from where you want to start capturing in PC. Connect the handycam and the PC with the USB cable. (USB-Mode appears on the handycam LCD / viewfinder.) Start Windows Movie Maker. Click on the 'Capture..' link to start the wizard. Select the Sony Digital Imaging Device. Click Next. Specify the file name and path for the capture video. Click Next. Select the desired capture format and Click Next. (Leave it to recommended setting if you are not sure.) The dialog box now displays the Start Capture and End Capture buttons on the left and preview window on the right. Play the tape on the handycam. The video from handycam should appear in the preview window of WMM. Click the Start Capture button to start capturing the video. Click End Capture to pause or stop recording. Click the Finish button. The .wmv file will be saved in the path specified in step 7.
Oct 02, 2007 | Sony Handycam DCR-TRV265E Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder Logo
19 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
