Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Will not run at full r.p.m. it quits like you turned it off
  • Husqvarna Master
  • 7,482 Answers
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
Trimmer runs like it isn't getting full power and then quits altogether
It sounds like a coil issue or it simply may be a carb adjustment. Start with 1 full turn out on both low and high side.
Sep 16, 2015 | Garden
My 1998 Chevrolet Malibu is giving me trouble. It runs smoothly most of the time but often the engine will quit running while decelerating suddenly for a sharp turn of a full stop. How do I fix.
Save yourself some money , Take it to a ASE repair shop an have it diagnosed ! don't just replace parts have it hooked up to a diagnostic scan tool !
Jun 15, 2015 | 1998 Chevrolet Malibu
I have a 2000 Durango with a 5.9 liter and it wont turn over. Engine started running a little rough and then quite running all together. It turned over a few times then quit. there is oil in the dip stick...
way too much oil. check the coolant level as the sump may be full of water. It will run with a faulty o2 sensor. run fault codes as there could be a cam/crank position sensor problem
Dec 21, 2014 | Cars & Trucks
My laptop running windows 7, suddenly will not recognize the camera and download the pics
Quite normal the computer is saying its full or sometimes you have to turn computer off plug in camera turn it on then turn on laptop
so it will read.
Jun 02, 2014 | Nikon COOLPIX P100 Digital Camera
Engin runs fine for about twenty minutes then quits. oil level is full
try and run it with a loose gas cap the vent could be clogged then check for spark when the engine dies or even better get a inline spark tester then you can see it when its dieing
Jul 12, 2012 | Garden
99 Dodge Ram 1500 quits running. Guages go to
Sounds like a bad ignition switch.
Jul 25, 2010 | 1999 Dodge Ram
Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
77 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
