Question about MA Audio HK4000D Car Audio Amplifier
How do i get 17-18 volts to my amp? - MA Audio HK4000D Car Audio Amplifier
Finding Max 18 volt charger?
18 volt battery charger will give out 20 to 22 volts. and drop off while charging. to around 19 volts. its just finding the right amps. as this is the most important part. these can very from 3 to 20 amps. some cheap chargers are 1 or 2 amps and can take up to 8 hrs to charge a battery. as an even a charger that says 18 volts at 8 amps or 6 amps should be fine. really depends on the manufacture setup.
May 02, 2018 | Drills
Car has dieing while going dwn rd. Sometimes wjll start rght back up, other times we wait sometimes hrs. I've checked the coil pack& module both pcm &ecm were checked by g&s auto and said...
Code 17 & 18 are crank/cam correlation codes. Depending on what car you have, some sensors are dual sensor, crank and cam in one. Some are set up with up to three sensors. One crank and one or two cam sensors. I you have a dual sensor, I would replace it, but check the plug first. Sometimes corrosion can mess with sensors. Just unplug it and plug it back in. This usually takes care of contact issues. Clear the light and see if that code comes up again. If you have two or more sensors, then we are talking timing belt issues. To check code 26, you will have to check for voltage on that wire. Pinout and color codes are needed to find the wire from the ECM. Again not knowing your car, voltage could be 5,8, or 12 volts. Or real close to these numbers. If you don't see any voltage from here, the ECM is bad. Quad drivers either work or don't work. 56 is an 02 heater code. This could make the car run a little rough, but not cut out. Now the injector test, if you didn't get a reading from the injector, it is bad. This will make the run real bad, Because you lost that cylinder.
Jul 13, 2013 | Cars & Trucks
Porsche cdr22 volume increases and button will not dcrease
Most of these things use an IC to control things like volume etc. Chances are that will have failed.
Feb 25, 2013 | Pyramid Cdr22kit Am-fm Receiver Cd Player...
I need to know what the power consumption is for my serger as we will be moving off the grid. thank you.
Hi gladysmorin...
We would need the info from your metal tag on the surger motor before we can tell you what the power consumption would be.
So you will need to look on the metal tag that is attached to the surger motor and retrieve that information, you will need the amperage and the voltage.
But you can also figure out how many watts any appliance will consume in power...you will do some math.
If you want the watts,volts or amps for a given appliance follow the examples below:
Amps X Volts = Watts
example: 3.0 amps X 220 volts = 660 Watts
Watts ( / ) divided by Amps = Volts
example: 100 watts ( / ) divided by10 Amps = 10 Volts
Watts ( / )divided by Volts = Amps
example: 60 watts ( / ) divided by 120 volts = .5 Amps
( / ) = the right slash means...divided by.
Please take time to rate me
Sep 06, 2011 | Singer 14SH654
Is a Hampton Bay HBD240A window A/C 120v or 240v?
I have never seen a 240-volt window A/C unit for the U.S. market. So, my guess is it's 120 volt.
The best way to verify this is to read the name-plate on the unit.
Another way is to look at the plug on the unit's cord. There are at least three types of plugs :: 120 volt, 15 amp; 120 volt 20 amp; and 220 volt. 120 volt 15-amp will fit a standard household wall outlet. The 120 volt 20 amp plug is similar to a 120 volt 15 amp, but will not plug inot a standard household outlet. The 220 volt plug is altoghether different.
Charlie
Jan 08, 2011 | Heating & Cooling
The gear transmission always slip to gear 3
Having owned a trans repair shop in the past,I will be kind here
Get rid of it, any way you can. It is 17,18 years old.
Do not buy another van type vehicle,any make or model.
Nov 28, 2010 | 1993 Dodge Caravan
Purchased "Reliance Lowboy electric water heater"
The water heater has two 4500 watt elements.
However both elements are not turned-ON at same time
So the water heater is 4500 Watts
Volts x Amps = watts
Amps =watts divided by volts
Amps = 4500 Watts divided by 240 Volts
Amps= 18.75
So that says a 20 amp breaker ... except for the 80% rule
80% rules says for safety, your Amp rating should be multiplied by 80%
20 amp breaker X 80% = 16 amps
20 amp breaker is actually safe for just 16 amps, and your water heater draws 18.75 amps.
The calculation shows you need a 30 Amp breaker.
30 Amp breaker requires 10 gauge wire.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Nov 02, 2010 | RELIANCE ELECTRIC WATER HEATER
Yamaha r1 2007 showing false hi and wont start
did you mean FI light?? start with the switchs side stand, neutral and clutch. if any are not working the bike won't start. hope this helps
Mark
C.C. Motorsports
Feb 20, 2010 | 2008 Yamaha YZF-R1
Need fuses for samson amp
The manual recommends 4 Amp Slow blow for 115 volt operation or 2 Amp Slow blow for 230 Volt operation for the 201a.
http://s3.amazonaws.com/samsontech/related_docs/Servo201a_OM_5L_v1_1.pdf
For the 260 Amp manual shows 10 Amp normal for 115 volt operation and 5 Amp nomal for 230 volt operation.
http://s3.amazonaws.com/samsontech/related_docs/ACF1AAF.pdf
Dec 31, 2009 | Samson Audio Players & Recorders
Can I use a 5 amp 240v AC domestic fuse to replace 5 amp 12v fuse
A fuse is rated for it's current carrying capacity so yes you can use a 240 volt 5 Amp fuse in a 12 Volt circuit.
The Voltage is given to indicate the insulation of the fuse, i.e. if you used a 12 volt fuse in a 240 Volt circuit it may arc and therefore is not suitable. You can always use a fuse with a higher voltage rating in a lower voltage rated circuit.
A 5 Amp fuse will carry 5 Amps indefinately and will only blow at 2 or three times it's rated current.
Oct 26, 2009 | Max American Terminal 30 i Fuses
Open Questions:
MA Audio HK4000D Car Audio Amplifier Logo
Top MA Audio Car Audio & Video Experts
Mark Skinner
jamie suver
Level 1 Expert
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
