Question about Philips Televison & Video
How do I remove the y-sustain board from a philips 42pf7321d/37 plasma tv? i have removed the screws and cables? It appears there are three heatsinks that are mounted to the board and the chassis but none have a way to remove them...
  • 3 Answers
I think rubbers under the board hold the board(these rubbers prevent the board touch the panel). I had the same problem. After make sure you remove all screws, pull the board harder from one edge.
Posted on Sep 22, 2010
Philips TV, Model Number 50PFP5332D/37, the screen starts out all black, but then slowly the black starts to dissipate and the picture starts to come through. However, the picture is all gray & fu
You more than likely heard a pop noise when this failed, the infamous pop of death when the Y sustain module fails. First check the various fuses located on the Y and X sustain modules. If a fuse is open you have lost the large IC on either PC board. These boards are located left side 3 module and far right side module with ribbon cables attaching to display panel. This can be a complicated repair due to one of the buffer modules failing, The Y sustain will be identifies by Samsung drawing number LJ92-01200A, The Buffers are LJ-92-01202A, LJ92-01203A. This is most likely a job for a pro because 1 of or all 3 modules can be at fault. Some services on e-bay for these modules offer rebuilding the Y-main module and also testing the Y-buffers. If you want to DIY this TV this would be the best Idea, send three boards to a rebuilder on E-bay.
Mar 05, 2013 | Philips 50PFP5332D 50 in. Plasma...
I have a Phillips 42in plasma 42PF7321D/37 when you turn tv on green light lights up you have sound and picture flickers a few times and then picture is fine and looks great. Noticed menus are hard to see...
I would certainly say the problem is in your power supply. Chances are real good that two capacitors are bad! You will have to remove the back cover...this is tedious and requires patience. You will be concerned with the board on the left side. You will have to remove the screws on the power board to lift it and see the top of this board. You should see at least one bulged capacitor. Replace, and you can bet the other next to it is bad. And another note..there may be a small cap at about 16volts at 10Mf that needs attention. These are clues and should help with repairs! Thanks for asking.
Aug 21, 2010 | Philips 42FD9954 42 in. Plasma HDTV
When I power on my 42PF7321D/37 Philips Plasma TV the green LED comes on then turne into a flashing red LED. Flashes 4 times then space then four times. TV will not turn on.
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this helpout........
Aug 03, 2010 | Philips 42PF7321 42 in. Plasma HDTV
No power to my Phillips 42 inch Plasma 42pf7321d/37, just a red blinking light
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at Shopjimmy.com
Sep 05, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips ssb
It is pretty much a plug and play. It is more time consuming than any degree of difficulty.
You must make a strong mental note of where each screw goes.
Simply disconnect the Molex connectors and the screws on the Signal Board; you're pretty much reverse the process. No cutting or soldering is required!
Dec 08, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Checking voltage on 42 in philips plasma
You're right. The YSUS board is gone. And most likely the Y SCAN UPPER & Y SCAN LOWER boards also gone. You need to replace these 3 boards. The original boards are from Samsung and you can get them from Samsung. The three boards may cost you US$400 more.
Aug 18, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Philips 42PF7220A/37 Chassis Number BP2.3U
I think its something on the picture frame board or on the line output board. I would sway to the line output simply because I think but not sure that error code is linked to the line output stage plus when you unplugged the cable the voltage seems within parameters. Good luck.
Aug 04, 2008 | Philips 42PF7220A 42 in. Plasma Television
Philips 42PF7220A/37 April 2006. Chassis Number BP2.3U
Most likely the YSCAN UPPER board and/or YSCAN LOWER Board also gone. Your new YSUS board may damage again if you don't replace the bad YSCAN boards. Try to replace the three boards together and then to verify which boards are bad one by one. Good luck.
Aug 03, 2008 | Philips 42PF7220A 42 in. Plasma Television
Phillips 37pf9975/12
the middle board = main power board
left board= )Y) sustain board
right board(X) sustain
lower board( input board) = SSB board
call andrews electronics for part price
Oct 08, 2007 | Philips 37PF9975 37 in. HD-Ready Plasma...
Televison & Video Logo
199 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
