Question about Frigidaire ATF6000ES Front Load Washer
When it spin it is very noisy - Frigidaire ATF6000ES Front Load Washer
  • 3 Answers
Sounds like the tub bearings are worn.Which will cause a loud noise in spin only
Posted on Sep 12, 2010
Noisy on spin cycle "rattling"
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Mar 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water has been leaking out of the bottom of my washer, and it has been making a horrible grinding sound. It finally stopped spinning last night, though it makes noises and tries to run.
Hi just read your posting.Now when is the machine noisy?Is it when the machine pumps out the water or when the bowl spins.Sorry to ask you this but please be accurate when you reply to this question.The reason being is that if it is noisy when it pumps the water it could be your pump but if it is noisy when the bowl turns for the spin then the problem will be your bearings and seals.Select a spin cycle and push start,is it noisy as soon as you push the start button?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Sep 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
Simpson 175 washing machine: spin cycle noisy and motor cuts out after short spin. Bowl feels stiff
Hi just read your posting.Now from the information on your posting the machine is noisy on spin and your motor is cutting out after a short spin.Is this correct?Now does the motor cut out during a wash cycle?If the motor only cuts out during the spin cycle , and with your machine being noisy on spin,I think the fault will be your bearings are corroded.With the bearings being corroded it puts more load on the motor causing the inbuilt thermal overload in the motor to activate and turning the motor off to save it from burning out.Please reply with additional information on, if it cuts out on wash and I am sure I can help you further.
Aug 07, 2010 | Washing Machines
Very noisy when spinning - suspect bearing problem. Would appreciate advice on bearing replacement. Model no. WF 240
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 30, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Aquarius 1100 wm63 very noisy spinning
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
Nov 27, 2009 | Hotpoint Washing Machines
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Hotpoint Aquarius WMA54 very noisy during spin
Hi, if your H/P is noisy on the spin cycle, just open the door and turn the drum a few times. If you feel some play, or kind of loud huming noise, then it is the bearings, very, very common on H/P WMA's.
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Frigidaire ATF6000ES Front Load Washer Logo
22 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
