Question about Midland GXT550VP4 (7 Channels) 2-Way Radio
Midland gxt850 My radio seems to recieve but i am unable to transmit. Can you help please.
  • Anonymous Dec 26, 2008
    When I try to transmit all of the icons come up and flash on and off.
wyoed1
  • 211 Answers
SOURCE: 75-822 midland radio
You have a bad detector in the radio. Needs serviced. Change the bad detector diode and it should work. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
SOURCE: wont change channels
First, try resetting the faceplate CPU by shorting the proper pins on the faceplate to radio connector on the back of the faceplate with a piece of wire... They are marked on the connector, if this fixes it for you, enjoy!
If that doesn't work, then remove the back cover of the faceplate and check the faceplate connector itself for bad solder joints. As a matter of fact, check the entire radio for bad solder joints before looking any further.
I bought one of these radios a short time ago; Everything worked except for LSB.
I was told by the radio shop I bought it from that I'd have to wait until June to get it fixed, so I opened it up myself to see if it was something easy to find/fix, since I felt that if it was anything major it wouldn't be able to get AM or USB either.
In my case, I found bad solder joints on the faceplate connectors and a bad solder joint on one of transistors attached to the heatsink.
Once I fixed those two things, it's been a great little radio.
Be sure to reset the faeplate after resoldering and assembling, to clear any errors from the CPU.
Posted on May 22, 2008
One Wire
  • 126 Answers
SOURCE: How far can that midland
Running most any regular cb, including this one barefoot (with no kicker), having a good antenna, set up with a good ground plane or a no-goundplane antenna, good coax; basically everything in good working order, you can usually bank on about 4 to 5 miles crisp and clear, and at least 6 to 10 miles fairly clear. Of course the further out you get it will start to fade out.
Some radios do better than others, but those are the general numbers I have seen in my years of experience.
Dean Pitts
Rollin CBs
Mt. Vernon, TX
SOURCE: i have lost my instructions
codes for radio
Posted on Jun 29, 2008
  • 39 Answers
SOURCE: midland squealing when talking
soundwas keying up at the same time.s like it could be one of two problems. a loose wire in the mic or some one near you keyed up the same time as you. if the wire in the mic is loose sodder it. If some one keyed up near you you might have blown the reciever chip.
Posted on Oct 06, 2008
Midland radio manuals
Download your manual from here: http://www.manualslib.com/manual/103191/Midland-Gxt-850.html
Aug 12, 2014 | Midland Radio Communications
I can recieve transmission from a motorola t5400 but cannot broadcast
Are you on the same channels? Are you on a repeater setting? What are your squelch settings?Are your batteries fully charged? Power is needed on transmit, not so much on receive
Mar 27, 2014 | Midland LXT310 2-Way Radio
My Midland walkie talkie quits transmitting about 3 seconds after I start transmitting
It is more likely a power issue. PTT switches do not normally cause a short circuit. Check the batteries, swap the batteries and see if that helps. Radios take a great deal more power to transmit than turn on or receive. If not the battery, try a low voltage battery, such as a cordless phone battery. If it still occurs, check your warrany and send it back to the factory.
Nov 10, 2013 | Midland Radio Midland X-tra Talk Frs/grms...
Will not transmit but will recieve
you may have a broken transmit wire in your mic get a mic tester and check it out. If its not the mic then its an internal problem
Aug 06, 2013 | Midland Radio 77-160 XLT 40 Channel ROAD...
Midland 1001lwx does not transmit any solution
take the little switch on the front and flick it to CB , turn up the mic gain and have at it.
Feb 16, 2013 | Midland 1001LWX CB Radio
I have an almost new Midland 75-822 that the WX works fine on, but the CB doesn't seem to receive, or transmit. It operates normally, but no reception, and no evidence of transmissions.
you'll need a schematic and some knowledge. there a two diodes that control the rx and two that control the dx.Check them to make sure they are producing the correct power out put if they are not you should replace all 4
May 10, 2012 | Midland 75-822 40-Channels Handheld CB...
I have a pair of Midland GXT500 radios. One operates fine, the other seems to be slightly off-frequency, in both transmit and receive modes, including the NOAA weather channels. I've swapped battery packs...
The short answer is yes. The long answer is: The problem sounds like the reference oscillator has drifted off frequency. You need to take the radio to someone who can do this for you. Look for a local HAM operator and ask him who could do it for you. A service centre probably can't these days, as they really only swap things out these days.
Unless you know what you are doing, you are likely to render the radio into a recyclable item.
Aug 17, 2017 | Midland GXT500 (14 Channels) 2-Way Radio
Midland alan 48 plus transmit scale not moving
Sorted now, soldered a new output transistor into the board and all working.
Dec 11, 2008 | Midland Radio Communications
Midland squealing when talking
Sep 15, 2008 | Midland 1001Z 40-Channels Base CB Radio
Midland GXT550VP4 (7 Channels) 2-Way Radio Logo
146 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
