Question about Whirlpool Duet GHW9150P Front Load Washer
Machine wont start come up with code f dl - Whirlpool Duet GHW9150P Front Load Washer
  • 1,531 Answers
This is a door lock mechanisam failure you nee to replaced the doo lock
Posted on Sep 12, 2010
Washer wont turn on. code is F dL. any thoughts?
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Wont start
The thing is with the new machines and codes, you have to go with what they tell you. without a model number i can not be 100% sure. But i can say with great certainty that a DL error is Door Lock. This happens to machines sometimes and causes weird problems. It all depends on how the door lock is acting. Sometimes you can't get the machine to start at all, sometimes it will run a bit and stop. To fix this a new door lock would need to be installed. With the model number, I can give an average price and a part number if you wanted to get the lock yourself and repair it :)
May 29, 2010 | Kenmore Elite 45986 Front Load Washer
Machine will not start dL code flashes
The door lock is not telling the control board the door is locked. You probably have a bad door switch or the wires to the door switch are corroded or broken.It could simply be a wire has come loose. Those washer do vibrate quite a bit.
Apr 16, 2010 | Washing Machines
Washer code says dl? and wont start
"Fdl" is a door latch error code. This is an indication of either a defective door latch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The following link explains how to troubleshoot the problem:
http://www.fixya.com/support/r4490349-fdl_error_code
I have included parts resources, if required, and the steps required to replace any defective parts.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashes "DL" and "F"
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Replace failed component.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont start unlees the button is held until it does start
try to restart,turnoff machine wait few minutes and turn on .
Feb 16, 2009 | Kenmore Elite 45986 Front Load Washer
Washer wont start
the dl code means door lock ,,,, you will need to replace the door latch assy to fix it / larryyb
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
Cycle wont start then I get Error / dl
the dl code is a door lock error,open door and examine door lock assy mounted on front panel.look for a plastic push pin approx 5inches up from square lock assy.if that pin is missing,replace door lock.if pin is there,you could still have bad door lock or loose wire connected to door lock.
Sep 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ghw9150pwo code
you got a door lock (dl ) issue, can be caused by a bad door lock, but can also be triggered by a baad CCU (located under main top assy.. might have also have a wiring problem leading to the lock assy "popped "off by chance.
Mar 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
