Question about D-Link DIR-615 Wireless Router
I'm trying to find my wep key or port number, I'm trying to connect my PS3 to the internet.
    Brigadier General:
  • 10,406 Answers
When you purchased the router, you should have run the "Wireless Networking Setup Wizard" to configure the router, to set an SSID, to set an encryption-level (use 'WPA' not 'WEP'), and to set a password (WPA-key or WEP-key or pass-phrase).
Use those values that you used when you configured your router to configure your PS3.
Posted on Sep 12, 2010
WHERE DO I FIND MY WEP KEY? I AM TRYING TO CONNECT MY PS3 TO THE INTERNET
WEP key is also known as your Wireless password. It is located in your Router Configuration settings. Access the default gateway of your Belkin Router and go to Wireless Settings. Look for WEP and it will provide you the WEP password to connect your PS3.
Jun 20, 2011 | Belkin Computers & Internet
I have recently added a laptop to my wireless internet which my ps3 runs off also. I haven't had any problems conneting to the internet until I added the laptop, now it doesn't want to connect. I went...
the wep key as it is commonly referred to, ( ~10 digit letters and numbers not cap sensitive) is a passcode to gain access to a internet through the wireless router only things i can think of are A. you put it in for your console along time ago and don't remember putting it in B. you changed the setting of wireless router to get it to work for laptop C. your stealing someone's internet and they decided to add a passcode to get in it
Jan 16, 2011 | Sony Playstation 3 (PS3) Console
PS3 error code downloading patches. Prior fix-ya advise inop. Need help fixing router problem. Conflict with Ps3.
0710102 - Error DNS, DNS server not available.
8001050B - Don't start demos on the hard disk when you have a Blu-Ray added. Unknown cause.
80010510 - Don't start games on your hard disk. Unknown cause.
8002b241 - DVI has no audio.
80028EA5 - Unknown.
80029023 - Exchange of key information timed out.
80029024 - The Attempt to obtain an IP address timed out.
80029564 - Game downloaded does not install. Unknown cause.
8002F997 - You cannot upgrade the XMB firmware.
8003051E - Game does not write.
80031150 - The settings are not be save. Possible System blue screen "Setting information is corrupted. Press the X button to repair and restore default".
80130203 - PS3 connects to the Internet, but not to the PSN. This could mean that the ports needed to connect to Store are not configured.
80710092 - "An error occurred. You were disconnected from the Playstation Network" - (the Internet connection lost?).
80710102 - PS3 can not start the connection with the information configured with the IP router. Try renice the router.
80710541 - The connection to the server timed out.
80710B23 - PSN is offline, or the PSN is too busy to respond.
80710D23 - Off the PS3 for a while (30 min) with the AC switch (not standby mode).
80029024 - "Could not get an IP address."
80028EA5 - Unknown - User cannot connect to PSN. Sony said user to take to get the PS3.
8002F997 - Trying to update the PS3 firmware, downloading the update file for USB and attempt to install failed.
80710016 - Playstation Network is offline.
8013013E - WEP keyError, replace WEP key for all the numbers and try again, or to replace WPA.
8013030F - Check page of the router, off SSID Broadcasting.
8002F994 - Many people are making downloading updates. Please try again later.
80028F10 - Go to Settings and choose presentation HDMI (or whatever your connection) and choose Auto, not Custom.
8002A705 - Unable to connect to. Server. Check the router settings doors.
80030920 - An error occurred during the copy operation. The file may be corrupt or there is a lot of memory. Try copy of its original location.
80010514 - total failure of the Bluray drive.
May 06, 2010 | Computers & Internet
How do i hook up wireless internet to a playstation 3
go to the settings tab on ps3 go to network connections then look on the back of your modem and #'s in [ ] write it down cuz thats your wep key u need that 4 everything and put that number in the wep key space on ps3
Oct 22, 2009 | Sony Playstation 3 (PS3) Console
Cant connect to the internet, and not sure what my wep key is
ok playstations arn't the best for connecting to the internet but they can connect none the less. first get your router closer to your ps3 to make the connection strength better or purchase a signal booster. get you connection evaluated and see if your ps3 is working properley by disconecting it from the mains for about an hour and then reconecting it to the mains. it might connect then but try a signal booster, it might help but it's probably your internet. - good luck
Apr 30, 2009 | Sony PlayStation® 3 (60 GB) Console
I have a netgear wireless router, I also have a new PS3, I want to access the internet via the PS3 but have lost my WEP key for the router. Whats the easiest way of finding the WEP key Thanks Darren
wep key or router administrative password?
if you have router admin password, you just go to your router settings and reset, delete all WEP key setting
(i assume one that connect to your router is only the PS3)
The setting should be web-based.
connect a pc to your router using LAN/ethernet port.
Access the router (you should know the router
ip address) via IE ex: http://192.168.0.1/
Read your router manual for details.
Dec 26, 2008 | NetGear MR814 Wireless Router
PS3 Trouble due to WEP/WPA-PSK Key trouble
You can always press the reset button and wipe all settings out. You will have to re-enter passwords and encryption to protect your network.
Dec 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
PS3 WEP Key Problems
if its asking for a WEP key then your wireless network is a secured one..you will need to put the same key as you had originally used while setting your wireless network..are you able to connect to the wireless from a laptop?
see the message that comes on your ps3 when you scan for available networks..you will know if your wireless has security..
you can chnage the security of your wireless by logging oto it by typing 192.168.1.1 in the laptop browser and then configure/change security settings..hope it helps..
Oct 29, 2008 | Sony Playstation 3 (PS3) Console
Wep key for ps3
you will need to obtain your wep key no matter what...you can get it from whoever your router company is (if it is a linksys then call the linksys support number and obtain the key) in most cases thought the wep key is located on the router itself near the bar code. It will be a long number, When you get it and enter it in to the network settings then it should pick up the signal
Feb 09, 2008 | Sony Playstation 3 (PS3) Console
SSID and WEB KEY number
i WANT TO CONNECT MY PS3 USING MY WIRLESS ROUTER BUT DON'T KNOW HOW TO CONNECT IT CAN YOU HELP
Jan 04, 2008 | Linksys Wireless-G Broadband Router
D-Link DIR-615 Wireless Router Logo
200 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
