Question about Viking Professional VCBB363 Bottom Freezer Refrigerator
We have a Viking Professional VCBB series refridgerator/freezer. About 6 years old. Does it have a changeable water filter for the ice maker? The cubes taste funny....I can't seem to locate a filter. Thanks.
  • arm7117 Sep 15, 2010
    Thanks....They built cabinetry around the fridge. Can't move it out to check because they also built a baseboard around the front. Thanks anyway.
  • 944 Answers
It is usually will be located at the back side of your refrigerator at the bottom or at the middle side like this.
Click here for manual
Posted on Sep 12, 2010
Freezer not cooling properly. Temperature alarm went off. Turned off now.
Look inside freezer on the rear wall to look to see if there is frost buildup. If yes then unplug and manually defrost defrost for about 3 hours if you only open freezer or place hot water in a bucket and place inside freezer and close the door. Let me know by answering my post here, Thanks John T.Appliance 911
Contact
click below for parts breakdown
I have a feeling the problem could be 1 of three things=> WR9X520 Defrost Timer, WR51X465 Defrost Heater or the WR50X0131Defrost Thermostat
May 28, 2015 | Viking Professional VCBB363 Bottom Freezer...
Ice maker not making enough ice
Hello Raeshel - First confirmed that the ice maker is not turned off. When was the last time the water filter was changed? Typically filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. Also the ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer but be careful to not melt any plastic parts! Make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. Should these suggestions prove to be ineffective, contact a professional to move forward accurately.
Dec 29, 2012 | Electrolux EW23BC71IS (226 cu ft) Bottom...
Water leaks under viking professional and there is about a 1/4 inch build up of ice on floor of freezer(which is on the bottom) on the floor of the pull ot freezer
Your drain is plugged. Basically the freezer goes into defrost and melts frost off the condenser coils. A big piece most likely fell off and freezer came out of defrost before it coulld melt and drain out completely. To fix you have 2 options. Have towels
#1- move contents of fridge and freezer to a backup fridge. Leave unpluged with doors slightly opened for 24 to 48 hrs. Use towels to cleanup any water. Plug back in wait 2 hrs to make sure temp gets back down before putting contents back in fridge.
#2- Remove contents from fridge and put in ice chest. Have towels ready. Remove ice maker ( if there is one) usually two screws on top hard to see and one on bottom. Disconnect the quick connect for the ice maker. Remove screw on back wall. Be careful when removing air vent on back wall. Its plastic and can break. Remove back panel. Look on the silver plate under coils and you will see ice and where the drain is. Remove ice than pour hot hot water down drain until it flows freely into drain pan under fridge by compressor. It may look like there is not ice make sure othyerwise you will be doing this all over again in a few days. Once water flows freely put everything back together wait about 2 hrs for freezer temp to get cold enough and than you can put contents back in freezer. If you have any question or need help please feel free to comment me back.
Jun 05, 2011 | Viking Professional Series VCBB36 Bottom...
Still leaks
it is condensate from the auto defrost bin/drain pipe,locate and clean with clorine bleach(stops nasties growing....)
Jun 02, 2010 | Viking 42 in Built In Professional...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
Ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Viking Professional VCBB363 Bottom Freezer Refrigerator Logo
367 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Joseph Hoffmann
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
