Question about Samsung Televison & Video
Samsung LCD television Model Code LNS4041DX/XAA VERSION AMO4 The screen has dark spots and stains.
SOURCE: Red spot on LCD
My friend's TV was well out of warranty and a Sears (the retailer) tech agreed that the engine needed replacement. They called Hitachi Customer Relations who will send the part to the home at no charge. Sears did not charge for the service call, but will charge $242 for labor to install the parts and adjust the TV.
Thanks for the posts. He saved $$$$.
Posted on Jan 26, 2008
SOURCE: samsung lns4041dx/xaa
Same problem with my set. The volume was either fully up, or fully down (usually down), and other controls didn't work- like I couldn't access the menus and could not adjust the width of the screen/aspect ratio.
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Posted on Mar 14, 2009
  • 1779 Answers
SOURCE: Dark spot on LCD screeb
It sounds like a couple of your back lights have burned out. I suggest taking it to a service center to have it looked at to make sure.
Posted on Mar 21, 2009
roety
  • 585 Answers
SOURCE: Samsung LNS4041DX/XAA White horizontal lines
Hi my name is Roety,
I can help you with your issue ,
If the lines are present on every input you most likely have a bad screen. We usually replace the mainboard first because its cheaper .
Check part prices at encompass.com login as a guest
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Dec 01, 2009
  • 6 Answers
SOURCE: Have sound but no picture on Samsung plasma
It's a pretty common problem. The no picture but sound problem is usually the y sustain board. I've replaced 2 on mine now. The 680uf 35V capacitors usually are bulging because one of the power transistors went and took them out. This has happened to both of the y boards I had. One time the failing y board took out the buffer boards too, and once it did not. The fix is super simple and anyone with even the most rudimentary knowledge of computers or electronics can do the labor yourself. You should do the simple stuff first by just doing a quick test with a multimeter. Just check the power coming to the y board. After that you can just remove the y board by removing 3 cables and like 3 screws. Plug in the new board and it's done! You can source the parts from a place like shopjimmy or discount merchant. 3 boards were like 200 bucks. 1 board is like 100 bucks. Labor took me 15min. Think about that the next time an electronics repair place charges you 1000 dollars. Of course they check everything (Yeah right) and warranty their work (I don't) but if you check the service manual it states that this is the most common repair. Look for the Canadian manual online. Hope this helps!
Posted on Feb 23, 2010
My Samsung LNS4041DX/XAA audio is degraded
https://www.cnet.com/forums/discussions/samsung-lns4041dx-xaa-lcd-tv-has-sound-but-no-picture-513963/
Apr 07, 2017 | Samsung Televison & Video
Dark screen on samsung lnt4669fx lcd tv, what could be the problem?
As you suspect, it might be of T'Con board fault. Check all the flat cables connected to T'Con to panel should be checked first for any loose contacts. Re-seat them once. If you wish to know more, check this site. It has illustrations of screen shots, for Samsung LCD TVs, with a faulty T'Con board. Can compare these images with your TVs.
Jan 24, 2013 | Samsung LNT4669 TV
Sound but no picture or anything on the screen.
Ur LCD inverter backlight board is dead.Replaced this LCD inverter baclight board will get ur picture back.Tries Websites Shopjimmy.com,Ebay.com to buy a LCD inverter backlight board for the replacement.It a long board in shape.
Mar 23, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
I will reply asap
Thanks
Dec 01, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Our Samsung Model HLP5063WX/XAA - dark images
I suspect that you may need to replace the ballast for the lamp and the power supply board.
Oct 30, 2009 | Samsung DLP HL-P5663W 56" TV
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung lns4041dx/xaa
Jun 03, 2008 | Samsung LN-S4041D 40 in. LCD HDTV
Televison & Video Logo
121 people viewed this question
Henry  Thomas
Henry Thomas
