Question about Refrigerators
GE TFX22PRXB, stopped cooling. Cleaned coils underneath, cleared blockage in freezer drain tube. Still would not cool. Removed panel from freezer and found lower set of coils frozen solid. Removed all ice with hair dryer, reassembled and still doesn't cool. Checked freezer this morning and lower coils were starting to freeze again, but only down the tube on the left side and the bottom two loops of the lower coil. What do I need to do?
SOURCE: Kenmore 52603100 refrigerator was icing up, now has stopped cooling!
Here is your problem:
There are two temperature sensor wires; one should be routed around the vent on the upper left corner of the "ceiling" of the fridge. It will route inside the plastic cover in the back upper corner.
The second one is critical. It originates inside the cover and must pass through the wall of the fridge into the freezer and rest just inside a hole in the rectangle that passes through from one side to the other. If the very tip of this sensor is not well inside the freezer, the system will think the freezer is too warm, never turn off and the lovours inside the plastic housing described above will jam with ice and get stuck. This piece will have to be replaced but will continue to freeze and break until the sensors are placed in the correct locations. Don't ask me how I know all this.
Good luck.
Posted on Oct 15, 2008
  • 4 Answers
SOURCE: GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Posted on Jan 01, 2009
  • 111 Answers
SOURCE: /gss22wgpjbb Ge side by side fridge Keeps freezing
automatic defrost its not coming on check the heather or hi limit
Posted on Jun 17, 2009
  • 363 Answers
SOURCE: whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Posted on Jul 28, 2009
Sea Breeze
  • 4655 Answers
SOURCE: my frig is running but not cooling - frig is 50
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Posted on Jan 23, 2010
Testimonial: "Thanks for the quick help - yes frost on back wall. Once I unload and defrost should I then take out defrost thermostat? "
I have a GE GSH25JFTA CC refrigerator and it is not cooling properly. What should I check or replace?
Depending how long the power was off you may have an ice blockage in the freezer. Normal cooling causes the freezer coils to build up frost and snow coating all over the coils. A normal defrost cycle melts that frost/snow off and keeps the coils clear so the fans can move air through the coils.During the power outage the frost may have started to melt wetting the snow. If the refrigerator then came on and re-froze the wet frost/snow into a solid block of ice, the normal defrost cycle would not be able to clear that solid ice out. So it may be blocking the air flow. Remove freezer back panel and see if there is ice back there. If yes--use something like a hair dryer to melt everything out until it is completely clear. Make sure the fans are running also.
Apr 14, 2015 | GE Refrigerators
At the bottom drawer of freezer it has a frozen layer of ice which has now stopped the drawer from being removed.
Underneath the evaporator (cooling coil) located in the freezer is a drain pan and drain tube used to carry away the water that accumulates during the defrost cycle. This pan or drain line is probably plugged with debris.
Mar 01, 2015 | Refrigerators
My Wood's All in one frige is leaking water underneath the crispers. There is a pool of water everyday underneath. I make sure nothing is in front of the fans on the bottom, but I still have this...
Sounds like cooling coils inside ref. that cools the water before the dispenser in the door.
These coils are in the back bottom of ref, behind crispers. They may be leaking.
Here is some more help.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
If you need more help GO HERE:
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 25, 2011 | Refrigerators
Whirlpool up and down, water pooling on floor from under refrigerator. Pan full in back. How to empty it==can't get it out. Pan moves alittle from side to side
Leo Ponder
imufo2
Leo Ponder
imufo2
Sep 23, 2011 | Refrigerators
Water in bottom of the refrigerator,removed panel in freezer,drian pan frozen.defrosted and drain tube is not clogged,after 7 weeks or so same problem,drain pan and tube are frozen,then water drips down...
Leo Ponder
imufo2
Ice builds up in freezer than leaks out around seal
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 09, 2011 | Maytag Refrigerators
Ice collecting in bottom of Kenmore Coldspot freezer side and then melting and ending up on the floor. It was first discovered by a puddle on the floor. This model--"59282990"--has...
Leo Ponder
imufo2
Aug 09, 2011 | Refrigerators
Water is collecting in the bottom of the refrigerator below the drawers. Water was also in the lunch meat drawer.
Your freezer defrost coils are probably frozen. Or the drain tube is plugged. Remove the rear panel from the freezer and defrost the defrost coils if necessary. Make sure that the drain tube underneath the coils is not plugged with ice or other foreign matter. You may have to thaw out the tube. If you don't make sure that the tube is clear, excess condensate will continue to drain into the fridge. Good luck!
Sep 21, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
GE GTS22WCMBRCC, refrigerator and the freezer wont cool or freeze
possibly the drain tube for the condensate(water) is plugged due to ice having built up on freezer coils. Check coils to see if they are iced up. Sometimes especially in humid climates the defrost mechanism even if working gets overpowered by moisture. If so defrost coils manually and clear drain tube.
Jun 02, 2009 | GE GSF25TGW
Refrigerator side stops cooling
Drain stopped up.
Take out the bottom drawer in the freezer, look at the back wall and you should get a partial view of the bottom of the cooling coils. Directly below these coils is the drain area. You may need a light to see the drain hole. If this area is covered with ice then a hair dryer will help clear this so you can see the drain hole.
I have some O2 tubing that I put down the drain to clear any cloggs. Also, I seal the top of the drain hole around the O2 tubing with tape and use the air from my lungs to clear the drain tube. Pour a little water down this drain hole to make sure it’s clear.
Dec 17, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
