Question about Humminbird Fishing GPS Receiver
HUMMINGBIRD NS 25 SHOWS RECEIVER NOT CONNECTED HAVE CHECKED ALL CABLES AN ALL OK THE GPS RECEIVER IS A HUMMINGBIRD A GR3. ARE THERE ANY REPLACEMENTS AVAILABLE FOR THIS UNIT?
Hummingbird 898 gps receiver wire repair...
yes you can. However you must see if the power cables is o.k and everything is good.try again.
God bless you
Jul 13, 2013 | GPS
Moisture in antena
Hello there.
Please click here to find a replacement antennae for your Humminbird device.
Hope this helps.
Jun 05, 2008 | Humminbird NS25 GPS Receiver
Tip
Insignia gps receiver
my insignia NS-CNV20 car gps is not working propely.
my question is i need insert same map gps update for my gps?
on Sep 30, 2009 | Insignia NS-CNV20 Car GPS Receiver
Humminbird
My 787c2 screen just shows lines across it does anyone know were to get a new screen for it hummingbird says they don't stock them anymore try Humminbird Fishfinder Depth Finder Humminbird GPS Chartplotters...
Jun 14, 2013 | Humminbird Boating
I HAVE A HUMMING BIRD DEPTH FINDER, MODEL HDR610. I WOULD LIKE TO HOOK IT UP TO MY IH HAUL TRANSPONDER. IT IS A COAX CABLE. THE NEW HUMMINGBIRD IS A THREE WIRE CONNECTOR --CAN THIS BE DONE??
Hello
It is not possible to connect. Out three wires comes from Humming Bird, Black one is Negative, Red one is for 12VDC supply and the other is for buzzer. So it cannot be connected with Coax-Cable. OK.
Jul 09, 2011 | Hummingbird GPS
Insignia GPS INSIGNIA NS-CNV20 Pover Up and Shutting down
Try resetting your navigator by inserting a tin tool (e.g. unbent paper clip) into the reset port. A schematic can be found in the owner's manual. Also, ensure that the unit is securely connected to power or that the battery is fully charged. If these steps don't resolve the problem, return with the unit to the place of purchase to pursue service options.
Mar 10, 2010 | Insignia NS-CNV20 Car GPS Receiver
I have a hummingbird matrix 67 gps chartplotter fish finder. It developed a problem with the screen. The outer edges are legible, but the center is damaged. Is it worth repairing. Are there any other...
Hummingbird will refurbish that one for around 150US dollars, better then 500+ for a new one. If the screen is subjected to direct sunlight and heats up it can go out. This is why they discontinued the 67 model and replaced it with the 767.
Apr 21, 2009 | Humminbird MATRIX 67 GPS Receiver
Adapt 997c si gps to navnet furuno sounder
no can do you must have a Furuno GPS or a GPS with NMEA 0183 output. you could get that from the Hummingbird display but not straight from the antenna
Feb 27, 2009 | Furuno NavNet vx2 1920C GPS Receiver
Hummingbird gps ns25
Hi!
here's a user manual/installation manual for your sounder:
NS25
If the depth sounder portion works, I would suspect the settings are off (check first) or the gps circuit needs repair.
Best of luck!
Mike
Sep 02, 2008 | Hummingbird Humminbird 1155C GPS Receiver
Humminbird Fishing GPS Receiver Logo
216 people viewed this question
Top Humminbird GPS Experts
Mike Marcotte
Mike Marcotte
Steve
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
