Question about Craftsman Air Tools & Compressors
Pressure builds up and shuts off normally but air leaks out of pressure switch which is new.... please help do i need some kind of check valve?
    President:
  • Craftsman Master
  • 1,383 Answers
Check valve is a brass or steel fitting threaded into tank and is where discharge tubing from compressor connects. Remove tubing and spray soapy water on valve. If it leaks you can remove and try to clean debris from seat. Replace as necessary. You can use generic valve from www.grainger.com, just watch thread sizes. Good luck
Posted on Sep 13, 2010
Cl6506016
Hi Larry
Here are a few things to check, you may have already checked some of these.
Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
But it should not have air leaking out of it all of the time. If so then it is faulty and in need of repair/replacement.
Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
Gaskets...Check to see if your gaskets have failed.
You could have a gasket failure between the pistons and you will never know it because it shows no external air leak.
If this situation happens then the air will only cycle between cylinders and never build up the correct air pressure.
One way to check the gasket is remove the air filter, then put your hand over the intake.
Please take time to rate me
Bud
If correct then it will suck you hand against the intake.
If the valve or valves have failed then you will feel the air sucking in and blowing out.
Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
A worn cylinder will also contribute to the problem of pressure build-up.
Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Apr 30, 2013 | Air Tools & Compressors
I have an older i/r type 30 model 234 d4 that wont build air over 30 psi? The motor is a 1.5 hp and is wired correctly and theirs no water in the tank!!! Help!!
Hi dennis
Bud
Apr 11, 2013 | Ingersoll Rand Type 30 Electric Driven Two...
My ingersoll rand compressor won't get up to set pressure
Hi bryon
Bud
Bud
Apr 05, 2013 | Air Tools & Compressors
Want compress air
Hi james
Bud
Bud
Apr 03, 2013 | Air Tools & Compressors
I have a porter cable compressor, but the pump won't shut off, and the pressure won't build it
Hi
*Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
*Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
*Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
*Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
*Gaskets...Check to see if your gaskets have failed.
If correct then it will **** you hand against the intake.
*Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
*Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
Nov 01, 2012 | Porter Cable Air Tools & Compressors
Pump is not shutting off, and pressure not building up
Hi Kendal
Bud
Nov 01, 2012 | Campbell Hausfeld 26 - Gallon Air...
Hi Kendal
Bud
Nov 01, 2012 | Campbell Hausfeld Air Tools & Compressors
Compressor reaches upper pressure limit of 120 psi but does not shut down or increase in pressure. When manually shut off at near 120 psi it will hold pressure for extended time.
Hi
It will contribute to not shutting off the compressor motor thru the use of the pressure switch.
Sep 21, 2011 | Stanley Air Tools & Compressors
Porter cable air compressor wont build pressure passed 40 psi
Hi bakerboy1176...
Sep 05, 2011 | Garden
My air compressor with fill up to about 40 psi and then it just shuts itself off
Hi theyankees20...
Sounds like you have a pressure switch problem, it may have gotten out of calibration.
Check to see if your compressor has an adjustable pressure switch. If it does then adjust the screw/nut down (clockwise) to increase your shut off pressure...just go slowly on the adjustment.
I will include a few more things to check also...
Aug 29, 2011 | Pacific International Schwinn Hinge...
Air Tools & Compressors Logo
59 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
