Question about GE Microwave Ovens
The turn table goes clockwise sometimes & counter clockwise sometimes.It also makes a groumbling noise.
    Genius:
  • GE Master
  • 1,689 Answers
The motor for the turntable in these ovens is bi-directional. This is normal.
As for the noise, it is very common that the main turntable wheel track-ring under it is dirty at its wheels, or its pin-pushings have some wear. It is also posssible that the main turntable motor has become noisy from use and age.
I have had microwave ovens make a grumbly sound when one of the cooling fans are going defective.
Jerry G.
Posted on May 15, 2008
Why do I hear a popping noise when turntable revolves counterclockwise.
If the turn table automatically picks up the tone arm and starts the record and changes after the record is over, then you are haering the gear box.
Feb 23, 2015 | Samsung SMH1816S 1.8 Cu Ft Over The Range...
I have a kitchen aid microwave and when turning on sounds like the bird chirping around the bottom of the unit.
Does it have the option to turn the turn table off if so turn it off and see if noise goes away if so turn table motor very common over time it will default back to on on next cycle
Feb 20, 2015 | Microwave Ovens
Where is the rinse aid on a dishwasher?
It is located in the inside of the dishwasher. On kenmore /whirlpool/frigidaire/galax
there is a roundknob located in the soap dispenser box which you turn counter clockwise
and pull out.
this is where the rinse aid is poured in. There usually is a small window to see it.
On hotpoint, kenmore there is a large knob inside the door (usually grey) it turns counter
clockwise and pulls out.
hope this helps.
Mar 02, 2011 | Microwave Ovens
Why my new oster blender blade rotates counterclockwise and not clockwise?
It is a function of gearing or motor orientation, and it makes no difference which way it rotates, as long as all of the attachments need the same rotation....
Nov 06, 2010 | Microwave Ovens
I have a JES1142 which I purchased only one month ago. The turning plate rotates both clockwise and counter clockwise. When it rotates counterclockwise it makes a grinding sound. Why does it rotate bot...
It's normal for the motor to turn both ways, that's because of how the motor is made. As for the grinding noise, there's no reason the motor itself would make more noise turning one direction than in the other. The noise might be coming from the roller ring under the glass turntable. One of its wheels might be binding when it tries to turn counterclockwise.
Here's a test. Take the glass tray and roller ring out of the oven. Put a microwave-safe container with a cup or so of water in the oven and start it. Stop the oven and start it again, and the motor should turn the other way. If not, repeat this until you've seen the plastic coupling turn both directions. Note whether you still hear the noise as the motor turns each way. If you do, then there is something wrong with the motor and it should be replaced. If not, the noise is coming from the roller.
In either case, if the oven is truly only a month old it's still under warranty. Since you are concerned about the noise and are worried that the oven is defective, contact the store where you purchased it and see if they will exchange it or take it in for service. If the store can't help you, refer to the owner's manual for the service procedure to follow.
Hope this helps. Thanks for using Fixya!
Feb 13, 2010 | GE Microwave Ovens
Microwave, model # jes738wj02
It's normal for it to rotate in either direction. It has to do with the position of the motor and the instantaneous line polarity at the time the power is engaged.
But the grinding noise may indicate a problem...
You can do a quick check. You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58
If yours sounds like it's grinding, etc., you may have a bad motor.
To replace it, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 14, 2008 | Microwave Ovens
GE Spacemaker making odd noise
We are having the same problem with our XL1400. I suspect it has something to do with the turn table but don't know for sure. We would be willing to disconnect the turn table...anything to stop the noise but don't know how.
Mar 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1631BB005 making noise
Many thanks to e3enigma above! I removed the synch motor under the turntable; all other microwave functions work fine and the grinding noise is gone, hooray! A trip to the appliance parts store tomorrow for a replacement synchronous motor and all should be well. Thanks again!
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Unit does not work
open microve cover find magnetron crimp connections to magnetron
Feb 12, 2007 | Emerson MW8108P Microwave Oven
Microwave Ovens Logo
191 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
