Question about HP DeskJet D2330 All-In-One InkJet Printer
Printer on and off lights blinks
I send a job to printer, it reacts a bit then the printer on and off switch lights blinks and nothing happens. whats wrong ?
  • 1 more comment
  • zenboy May 14, 2008
    it is a HP deskjet D2330
  • zenboy May 15, 2008
    thanks I don't know where the message error should be but I checked inside and no paper jam... mystery... I filed the black ink cartridge, it was empty, and I filled the colour ones too !
  • butterflly Sep 03, 2008
    The on/off button is blinking & the printer will not print. There is no paper jam. When I try to print, is says there was an error with the print job. I cannot get the light to stop blinking despite canceling all print jobs, restarting the computer & unplugging the printer. I would appreicate any help as I have an at home business that is very dependent on this printer! :0)
    Thanks so much~
    Ali
  • 1,031 Answers
Check the error message on the printer there may be a paper jam so open the printer and clear the jam
Posted on May 14, 2008
Leds stay on and do not blink,
Hi. I have the same issue.
RC has brand new batteries, switches on and see to work properly.
Quad is charged. But LED will not blink.
RC and Quad do not see to connect.
RC lights keeps blinking.
What happened ? As far as I know nothing unsual. I bumbed the quad slightly on the roof of the living room where I was fligh it. Nothing unsual. I landed it a bit roughly. Then it stopped responding. I assumed charge was empty but when I charged , nothing happened.
Dec 25, 2013 | Protocol Manta 4-Channel Radio-Controlled...
Papaer empty
it first detects that no paper in the selected paper supply and it cause an error to your computer memory and printer memory so you must reset the job to clear the error on its memory to the two units.
May 15, 2010 | Xerox Phaser 7760/YDX Laser Printer
I send a print job to the printer and nothing happens
try downloading the latest print driver from www.kyocera.com or www.mita.com you may have a corrupt driver or it may be incompatable with an update
Jun 11, 2009 | Office Equipment & Supplies
Kyocera FS-1020D lights blinking but doesn't respond
Fuser error (6000 error)
Contact your Kyocera Mita dealer.
Unfortunatly there is not much You could do Yourself
This error means that the fuser is either damaged or not connected properly to the rest of the printer. If its connection error You could try to fix it but in most cacses the fuser is just broken ie. overheated due to not enough air flow.
May 28, 2009 | Kyocera Mita FS-1020D Laser Printer
9403 monarch printer/hooked to lantronix print server
If the printer doesn't react when you send a print job to it (either prints, or displays an error code on the display) and just sits there doing nothing, it generally means the print job didn't get to the printer. Check your communication settings. The printer comm settings must match the settings in your software. The default comm settings on the printer are:
Baud : 9600
word length: 8
stop bits: 1
parity: none
flow control: dtr
Apr 27, 2009 | Monarch 9403 Thermal Label Printer
Help! the green light flashes then nothing happens
The exact same thing just happened to me (WD elements 500 gig) and it's only about 10 months old. I called the customer help line (on the official website) and after they asked me what the serial number of my HD was they were going to send me a new power supply. Simple as that. They said they'd be able to send it out early next week. I'm hoping that the HD didn't get fried and it's just the power supply but what you've described is EXACTLY what is happening to mine.
Oct 31, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Printerndoes not respond
I thought my printer died on me, but it turned out it was a simple paper jam. The whole printer just locked up because of a paper jam! All I had to do was open the top compartment, remove the toner and get rid of the paper jam
Jul 25, 2008 | HP LaserJet 1320n Printer
5240 brother
I just solved my similar problem- switch off printer, open front door, hold down go (blue) button. Now switch on, holding the go button for about 10 seconds then closing the door.This left the lights all off, green light only when pressing go. Switch off then on, it worked! hopefully this helps someone else. Ross
Apr 18, 2008 | Brother HL-5240 Laser Printer
HP DeskJet D2330 All-In-One InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
