Question about Acer Computers & Internet
RAM low - Acer Computers & Internet
    Guru:
  • 689 Answers
If you are conidering upgrading correct ram module make sure you have correct specifications number type of connectors,etc even speed--id reccommend the taiwanese brands purely because they must have a good understanding of cross-platform compatability
Posted on Sep 12, 2010
Memory problems
How to prevent low memory problems Running fewer programs at one time can help prevent low memory problems and information loss. It's a good idea to observe which programs show signs of low memory conditions and try not to run them at the same time.
However, it's not always convenient or practical to run a limited number of programs. Signs of low memory can indicate that the computer needs more RAM to support the programs you use. Here are the recommended ways to solve or prevent low memory problems:
  • Increase the paging file (virtual memory) sizeWindows automatically attempts to increase the paging file size the first time your computer becomes low on memory, but you can also manually increase it up to a maximum size that is determined by the amount of RAM installed. Although increasing the paging file size can help prevent low memory problems, it can also make your programs run more slowly. Because your computer reads information from RAM much faster than from a hard disk (where the paging file is), making too much virtual memory available to programs will slow them down.
    For more information, see Change the size of virtual memory.
  • Install more RAM
    If you see signs of low memory, or if Windows warns you about a low memory problem, check the information that came with your computer or contact the computer manufacturer to determine which type of RAM is compatible with your computer, and then install more RAM. To install RAM, check the information provided by the manufacturer.
    For more information, see Find out how much RAM your computer has.
  • Determine if a program overuses memory
    If the computer becomes low on memory whenever you run certain programs, one or more of those programs might have a memory leak. To stop a memory leak, you need to close the program. To repair a memory leak, you need to check for updates for the program or contact the publisher of the software.
    To determine which program is using the most memory, follow these steps:
    1. Open Task Manager by right-clicking the taskbar, and then clicking Start Task Manager.
    2. Click the Processes tab.
    3. To sort programs by memory usage, click Memory (Private Working Set).
    You can also check for program errors and troubleshooting information using Event Viewer.
    1. Open Event Viewer by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking System and Security, clickingAdministrative Tools, and then double-clicking Event Viewer. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. In the left pane, click Applications and Services Logs to view error events. To see a description of the problem, double-click the event. To see if troubleshooting information is available, look for a link to online Help.
Mar 08, 2013 | Dell VOSTRO 3350
What does "low wash" mean on a 2007 dodge ram?
This indicates that your windshield washer fluid level is low. It's like the low fuel light, it gives you times to get some before you run out. If you check the washer fluid level and it is not low then the sensor is faulty.
best wishes
Jan 02, 2011 | 2007 Dodge Ram 1500 Quad Cab Sport
Hi, I don't know if I should get single or double sided ram for this mother board, and is low density ram ok? Thanks, Wayne
This mainboard uses DDR400 memory
A High Density module is by far much slower than Low Density module at the same speed rating say PC3200/DDR400. High density modules are FAR CHEAPER, less than half the price when compare with low density modules and hence high density modules will NOT work on 90% of today's PC chipsets. LOW DENSITY modules have 100% compatibility with ALL systems and ALL chipsets. HIGH DENSITY modules only have 10% compatibility and are VERY SLOW.
So AVOID those 'High-Density - 128Mx4 config 1GB modules which is usually UNBRANDED and is NO NAME!
With this in mind it is far better to use low density Ram. Most RAM cards today are double sided, it all depends on the capacity of the RAM card.
Please rate this solloution as it it much appreciated.
Thanks.
Oct 31, 2010 | Gigabyte GA-8S661FXM-775 MATX MBD SIS661FX...
Everything very slow
Hi Good day!! I'll suggest to you that if you want to boost your Computer try to increase your memory (RAM).low ram = low activities high ram = high performance.
Oct 16, 2010 | Microsoft Windows XP Professional
My system says, (RAM) radon access memory low cpu intel (r) pentium 4 cpu, version 2.80 ghz. RAM 256 mb. What can I do to resolve this problem. Dell 4700 dimension
Windows XP requires a "bare-minimum" of 128MB of RAM, works "OK" with your 256MB of RAM, if you don't open too many programs at the same time, and if you close/re-open Internet Explorer about once an hour of usage.
But, Windows XP would be _much_ "happier" if you added 256MB or 512MB of RAM, because it is telling you ("available random access memory is low") that it is using all the RAM.
Add more RAM -- your computer will run much better.
Jun 15, 2010 | Dell Dimension 4700 PC Desktop
2007 Ram Truck: where is low side of ac to recharge in 2007 dodge ...
The Low Pressure Side connector will be smaller than the High Pressure Side connector so the refill hose will fit properly only on the Low Pressure Side.
Read more: How to Recharge Air Conditioning with Freon in a Dodge Ram | eHow.com http://www.ehow.com/how_4484569_recharge-air-conditioning-freon-dodge.html#ixzz0uLXJnwvE
May 17, 2010 | 2007 Dodge Ram Truck
Low RAM
your p.c has four slots for ram 533Mhz. if your ram is low then you can purchase extra ram to speed up your computers processing power. either 512Mb or 1Gb sticks are available for your motherboard at 533Mhz. if this is not sufficient then you will have to upgrade your board to a newer more powerfull model. changing motherboard is not replacing the whole computer. see computer repair shop or vendor.
Feb 07, 2010 | Acer Aspire™ T180 PC Desktop
What Does it Mean If It say your Computer In low memory
Low on memory means the actual system RAM is over utilized. If your system has say 512 Mb Ram and you have XP operating system with some applications like MS Word and Outlook open and playing a game at the same time, these applications all take a chunk out of the RAM on the system untill it reaches a critical stage and the operating system detects there is not enough free RAM left to be able to run safely or efficiently and then warns you with the message "Insufficient Memory or Your system is running dangerously low"
Either Upgrade your system RAM or try and not run too many memory intensive applications at one time.
Aug 11, 2009 | Acer Aspire 5720-6661 Notebook PC
Computers & Internet Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
