Question about Toshiba e-STUDIO 50F Plain Paper Laser Fax
Shutting top down
After changing the Toshiba TK-15 toner kit, everything seems to be in its proper place, for some reason the machine won't completely close. I don't see anything that's blocking it. The toner kit snapped right into place. This is a major drag because I work for a law firm and we can't get any faxes out.
Any idea???
  • 130 Answers
If it was closing before it is some thing you did. Go thru the steps again, something is not in place.
Posted on Jun 11, 2008
How to insert bond paper in the machine
Dear Jonna
You can use any bond paper from casset tray up to 105 GSM and that of from MP tray you can choose up to 160GSM. Also setting to be made from the device driver for the type of paper as it require more heat energy to fix the image to the paper.
Jan 12, 2015 | Kyocera Ite-Tk-18-1 Tk-18H Toner Kit 7200...
How to change the country setting on FS-1320D printer.
I am an authorized Kyocera Tech on these machines and, from what i can find on KDA, the differences are more than just a soft switch setting. As a matter of fact, unlike most Kyocera MFP's, there is no where to change the destination code (country).
The EUR model is an 1102LZ3NL0 that requires 220VAC and uses toner TK-170. The USA model is an 1102LZ2US0 that requires 110VAC and uses toner TK-172.
These toners may be keyed differently but I do not think they have RFID or 2wire chips on them.
You could reflash the firmware to the USA model but I think that would cause a major failure without changing the power supplies and the fuser.
If you actually have the printer up and running you may want to simply consider buying EUR toner.
Dec 12, 2013 | Kyocera FS1320D Laser Printer
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
PC 921 toner light on. Replaced toner cartridge, light still on: won't function.
You see these machines needs to be kept very well.
1. the machine is not sensoring your toner.
a) need for the machine to be serviced it probably has a lot of spill toner inside.
b) toner empty sensor is not positioned properly.
b) the toner empty sensor is not functioning properly and needs to be changed.
Jul 14, 2011 | Canon PC-921 Black and White Copier
Hi iheanyippaul,
I see you concern, I believe you will need to check your toner if it is placed properly inside the machine seems that it is not locked/latched in its place to be able to print properly reason why you get a blank paper and black dust when printing.
Remove the Toner and re insert it again making sure the toner is set properly inside and also make sure the correct toner cartridge is installed, an incorrect or incompatible toner can cause issue of not getting to print anything on the paper or possibly not fit inside the machine correctly.
I hope this helps.
Have a nice day,
Jul 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have a Toshiba Dp85F Fax machine and need to replace the toner cartridge...I do not know what model number I need to replace it with. Please advise
Ink, Toner & Accessories for DP-85F Printers, Copiers & Faxes Select from the list below Compatible or Original ink and toner cartridges that work with your DP-85F.
TOSHIBA TK-18 Compatible Black Laser Cartridge, TK-18
  • - Condition: Compatible
  • - Page Yield: 6000
  • - Color: Black
  • - Printer Technology: Laser Cartridge
  • - Item Number: TK18-70
- OEM Part#: TK-18, TK18
Item #: TK18-70
MSRP: $114.99
Price: $38.99
Toshiba DK-18 DP-80/DP-85 Drum Unit
  • - Page Yield: 20000
  • - Color: Black item-color-black.gif
  • - Printer Technology: Drum Unit
  • - Item Number: DK18-70
- OEM Part#: DK18, DK-18
Item #: DK18-70
MSRP: $114.99
Price: $39.99
Toshiba DP85F Toner Cartridge, Black
Toshiba TK18 Toner Cartridge, Toshiba TK-18 Fax Toner
Nov 29, 2010 | Toshiba DP-85F Fax
Machine jamming up
it could be a problem with the motor, you might need to see a repairman
Jul 30, 2010 | Brother XL-2600I
"Toner Low" keeps showing
Hi Meridy!
There could be a few reasons for the Toner Low msg you're getting.
  1. The toner wasn't evenly distributed when the cartridge was changed (shake gently from side to side before installing)
  2. The cartridge wasn't properly installed (ensure that the lock lever "clicked" into place
  3. The corona wire wasn't cleaned when changing the cartridge or the the blue tab wasn't put back in place (this is less likely the issue but still a possibility)
  4. The new toner cartridge was old and is now defective
I hope this helps with your problem. All the best!
Jun 17, 2009 | Brother IntelliFax-2820 Laser Fax
Check the Color Toner Cartridge
Try to take out all the color toner.. And start the machine... If machine can startup properly, it will ask u to insert toner one by one...
PS: What is your current print counter?
Apr 17, 2009 | Toshiba Office Equipment & Supplies
Toshiba e-STUDIO 50F Plain Paper Laser Fax Logo
37 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
