Question about Samsung SyncMaster 204BW LCD Monitor
Monitor black, power button just flahes blue, tried disconnecting all cables for 1 hour, replugged cables back in, no "picture", power button just flashes won't change
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 13, 2010
I recently bought a Hp Lcd w1907 Monitor off craigslist, the screen worked fine for about an hour then went black, button stays blue. Now every time I power on the monitor it stays lit for 3 seconds...
hi the cause is screen back light not working properly. you need to remove the back cover of the monitor to access the internal part of the monitor. then look for the connector of the cold cathode fluorescent tube back light going to the power inverter board of the back light you will noticed a dry joints which cause a loose connection that is why you hear a sound that cause of spark. you need to re soldered the connector or replaced if totally burned.
Nov 08, 2012 | HP w1907 LCD Monitor
Viewsonic monitor vx2035wm goes black with a steady blue light on power button when the monitor is turned off or computer is restarted. Disconnecting it and letting it sit for a minimum of 24 hours makes...
I've been having the same problems with my Viewsonic.I plug it in and the blue light blinks but there's no picture it's just a black screen.I do know if Viewsonic doesn't repair my monitor I'll never buy anything from them again.I have the LCD Viewsonic 22' Vx2235wm monitor.
Does anyone have any idea what could be wrong with mine?I've bought a new video cable & video card but the monitor still does the same thing?Thanks
Oct 29, 2010 | ViewSonic VX2035WM LCD Monitor
Can't get a picture
Try this:
1. disconnect your LAN Cable (This is usually a Yellow / Blue colored cable) at the back of your computer.
2. Disconnect your Power Cable
3. Wait for 5 Minutes
4. Turn your Computer ON
5. if you see a picture now,
6. Plug your LAN Cable again
Hope this Helps. Message me. if this didn't work.
Oct 02, 2010 | Computers & Internet
If i turn my computer off for whatever reason, when i try to turn it back on, the monitor remains black, the blue power light flashes and the monitor emits this horrible hissing sound. I can eventually get...
Try this, no guarantees but it may need to be reset. Make sure PC is turned off. Disconnect the monitor from the PC and unplug it from the wall. Hold in the Power button for at least sixty seconds, then replug it in PC and wall. If it is reset it should start normally. If not it needs further diagnosis.
Jun 10, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor no longer works - all black
there is no reset button on lcd monitors, check power cable first, if the blue pilot led lights but no picture, you might need to bring the unit to the shop for servicing..
May 09, 2010 | Samsung SyncMaster 245BW Monitor
No picture on monitor (monitor turns itself off)
You will need to take it for repairs.
Sorry
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Dell E773C 17" CRT Monitor
My power light is on but the monitor is black. Is
your moniter is not broken your moniter's data cable is not correctly pluged.
Jul 30, 2009 | Dell E173FP 17" LCD Monitor
Samsung 226BW Monitor
What about the blue circle LED on the power button ? still blinking or not ?
For the record I've had some problems with this screen too, sometime I had to unplug and replug my Video Card (and the DVI Cable) and everything was back to normal
Hope it helped you
Nov 07, 2008 | Samsung 226BW Monitor
Printer trouble
Power cycle the printer. If problem remains, try a partial reset. You can do the partial reset as follows:
1. Unplug and replug the unit.
2. when lights flash on power up, hold down the ON/RESUME and PAGE SIZE buttons together.
3. When only the ON/RESUME button light flashes, you can release the buttons.
4. When the lights stop flashing, the reset is all done!
If problem remains, you are fully justified to ask HP to replace the unit for you (well, if you're still in warranty!). Good luck :)
Jan 18, 2008 | Office Equipment & Supplies
Open Questions:
Samsung SyncMaster 204BW LCD Monitor Logo
320 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
