Dear sir , i have an intex branded desktop with 17' TFT monitor . i m using windows XP in this system . sir today i increase the resolution of visual from XP and just after that my monitor gives an error (NOT supported.....H:98.4KHrz......V:59.6 Hrz.). i have tried my times by restart my system but it is still given this error. when i connect my CPU to an another CRT monitor it works fine . please give me some solution .
Sir i am using a intex crt monitor model 151.when i switch on the system booting is fine but when the windows comes ther is no raster only a message comes on the screen (high frequency). what is tha problum.
Posted on Mar 31, 2011
    Scholar:
  • 76 Answers
Obviously the graphics card is not capable of supporting the resolution you have set so it go's blank.
Although you can set the resolution via the computer the system will not change it back when you save that setting even though you see nothing, the computer doesn’t know you can’t see anything.
You need to go into the monitors menu (a button on the monitor front panel) and set it back to a supported resolution or default.
Start at 600x800.
Once you see an image on the monitor right click the desktop go to properties then settings and slid the screen resolution bar to the right to a resolution that suits you don’t go to high or you will get the same problem.
1024x768 would probably suit you.
Hope this helps.
Posted on Sep 12, 2010
The width of PC screen has suddenley widened, so that data is not viewable, how to I readjust it?.....
Right click on desktop and click screen resolution. Then select the recommended resolution for your monitor and click apply then OK. This sholud solve your problem.
Mar 02, 2014 | Dell 1702FP UltraSharp 17" TFT LCD...
Tip
Set Default Windows Font to 120 DPI for use with a large HD Monitor
Most users have either a 17" TFT montior OR an older CRT of the same size which works really well on the default 96 DPI and a screen resolution of 1280 x 1024 pixels OR the default 1024 x 768
However if you have a larger HD Monitor that will allow for a much higher pixel definition in line with 1080i and 1080p Televisions you might need to increase the DPI to 120 or some other custom setting to do this you need to right click the desktop and navigate to;
Display Properties > Settings > Advanced > General and you will see the pulldown menu to change it to Large Size.
It may ask you for the Windows CD however the files that are required should already be there unless you installed the Operating system from a minimized set of cabinet files on a slipstreamed CD.
on May 13, 2010 | Microsoft Windows XP Professional
Monitor's resolution need to be increased, how?
Hi
You don't say which operating system you are using.
The monitor resolves images across a fixed range of resolutions and resfresh rates.
It is the resolution of the graphics card or graphics adapter that can be changed, not that of the monitor.
Right click on empty space on your desktop > properties > settings.
Left click and hold on the slider and slide to the right in stages.
Each resolution change offers you a test page to accept or reject.
When satisfied Apply > Yes > Ok.
To reset the Refresh Rate:
Properties > settings > Advanced > Refresh Rate.
Then restart your computer.
Be careful not to exceed the resolution/refresh rate range of your monitor (1280 x 1024) / 75.0 Hz because if you do, when you restart the computer, the monitor will be unable to resolve the image and you will get a blank screen and/or an Out Of Range error message.
An out of range problem might only be resolved by using a different monitor to reset the resolution back to within the range of the preferred monitor.
Hope this helps
Aug 22, 2011 | Northgate MONNG7NSS 17" Flat Panel LCD...
I recently reinstalled my windows XP program and added the Dell E173FPc. At the beginning it work perfectly. I then downloaded all the XP updates and restarted several times. I now have a terrible...
Have you tried setting the resolution using display settings in control panel?
Go to control panel search for display. There you will find option to select monitor and resolution.
Oct 01, 2017 | Dell E173FPc 17" TFT LCD Flat Panel...
LIGHT VIEW 17" TFT MONITOR LM17SB OUT OF RANGE WHEN USING WINDOWS 7 WORKS FINE WITH VISTA
Set your resolution from "Display" which you can find in control panel. And fix the resolution at 1280 by 768.
Regards
Ashly
Feb 02, 2010 | Dell E173FPb 17" TFT LCD Monitor
I have samsung syncmaster 740nw how can i increase screen resolution to 1024x768?
you cannot set the resolution to 1024x768 but instead try 1280x720 or if you have graphics card try to set the resolution using its custom resolution by setting 1280x768.
It will surely solve your problem.
-ravi
Dec 31, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
How to change the resolution of Acer AL1702Wb 17
On windows XP and earlier :
1. Right Click the desktop
2. Click properties
3. go to settings
4. the resolution slider is there. Try different resolutions untill it looks good.
Feb 21, 2008 | Computers & Internet
My monitor is stuck in the lowest resolution
Distorted video after increasing the resolution in Windows. The resolution has been set higher than what is supported by the monitor, ... we recommend 640 x 480 with 256 colors or the lowest available setting.
Computer always boots into Windows safe mode. When booting into safe mode, the lowest settings are used, including your video card. This means that the resolution is 640x480, 16 colors when in safe mode.
Drivers & Downloads for your Dell Monitor Drivers & Downloads for your Dell Monitor ... Drivers & Downloads for your Dell Monitor
These's site click on them and follow instructions, Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | Dell E173FPb 17" TFT LCD Monitor
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
