from the phone press program key, than 01 for speed dial 1 and then the phone number you need to program in under speed dial 1, after done, press program key. to dial out press outside line key, than program 01 and it will dial out to that numeber. you have 30 speed dials per phone.
Try replacing ALL directionals for the side that is not working properly. That fast blink in the back usually means bad bulb, but could also mean bad relay.
Can you elaborate? You say emergency flashers work, but FR directional does not. Does the bulb-in-question light when the E-flashers are going?
just go to speed dial option in your cordless and enter the numbers you want on speed dial or directly you can contact with each other through cardless and no need of speed dial it can be done when you have two hand sets directly link with each other
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device. To manually create a speed dial entry
In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings.
Click New Entry.
In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK.
In the Speed Dial Settings dialog box, click Save.The entry is stored on the HP device. Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again.To create a speed dial entry from the Address Book
Under Address Book, click Select From.
In the Address Book dialog box, select one or more names, and then click OK.
My Mom had this same problem. I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
(To enter a 2-second pause between numbers, press [redial/ pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored. NOTE: • Storing a number to a speed dial location will overwrite the any previously stored number without warning. • When storing numbers into memory and the handset is idle (i.e., no key is pressed) for more than 0 seconds, it will beep rapidly, and then the phone will return to standby. Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.) Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number. Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
to programme speed dial just go to contact on your phone menu and select the conatct you want to speed dial and assign speed dialing number for the person or you type any number on your phone and press the harsh key like this (10#) and it will bring out the number assign to that spedd dial
First thing u need to learn that u can speed dial feature only for buttons from 2-9. So u need to first assign the no to one of the nos between 2 and 9 on the keypad, and then u can use ur speed dial feature...!!! Hope to recieve a good rating from u...!!!
