Question about Acer Aspire 4520 Notebook PC
Ntldr is missing how face the problem what we do
    Guru:
  • 689 Answers
I think this is some sort of booloader error
i suggest reformat and clean disk of corrupt sectors then re-install with guarenrteed genuine OS
Posted on Sep 12, 2010
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
How to fix a NTLDR is missing error
Fixes for NTLDR Errors
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Apr 06, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
NTLDR is missing
It means the the NT loader file is missing or corrupted. You need to repair/reinstall your OS.
Pity you didn't state the OS used.
May 07, 2010 | Acer Aspire 4720 Notebook
Ntldr missing when scanner is conected
change the boot order...in bios
Make first boot disk is hard disk..i think it is know with removable disk
2.CD-rom/DVD-RW
save the settings restarts then connect u r scanner
Jul 01, 2009 | Umax Astra 3400 Flatbed Scanner
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
NTLDR is missing. Say's to restart, just goes back
folow this link
http://support.microsoft.com/kb/320397
Apr 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
NTLDR is missing
  2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
  12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
Jan 17, 2009 | Computers & Internet
NTLDR missing
I can get into the Boot First Screen but can't seem to change anything within it... These screens seems to be selectively responsive to my key presses.... I can get the bios screen up, boot order screen up but not necessarily do anything within them... e.g. I can't restart the pc using ctrl alt del when the missing NTLDR message appears.... also I have put an XP disc in and it says to press any key to BOOT from CD .... I Do so but obviously it doesn't recognise it so it gives me the missing NTLDR message again! :(
May 24, 2008 | Microsoft Windows XP Professional With...
Ntldr
First check your bios & make sure it see's your hard drive & it's setup correctly. If it is there could can be other reasons for the missing NTLDR.
Suggest you take you Windows CD and boot to it. If your CD does not boot. Re-start the PC & start pressing the F8 key every two seconds. This will bring up a boot menue. Choose your cdrom drive.
Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy these two files to you Hd. copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
Replace the drive letter listed above for your cdrom's drive letter.
Once copy has been complete re-boot your Pc.
If you still get missing NTLDR. Do a complete reinstall of windows. Your personal data should stay intact.
Please post back if this has not fixed missing NTLDR, there are more fix's that can be applied. I only listed the most common.
Feb 12, 2008 | AOpen Motherboards: AX4SG-UN (AAX4SGUN)
Open Questions:
Acer Aspire 4520 Notebook PC Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
