Question about Honeywell CT3200 5-2 Day Electronic Programmable Thermostat Heater
Buttons on keypad not working.Honeywell CT3200
2 Suggested Answers
SOURCE: Honeywell 6160 keypad display not powering up.
I would check the connections first
Posted on Oct 14, 2009
Can I replace my old Magic Stat CT3100 thermostat with a Honeywell CT3200 thermostat?
yes just make sure u relace all the wires in proper order, r-rc, w , y g,, remove one wire from old stat and install on new one or make drawing and write down all wireing colours and letters
Dec 21, 2015 | Honeywell Heating & Cooling
How do I restart my airconditioning unit after a power outage?
If there is a panel you can open at the A/C. There may be a tiny reset button on the circuit board. Just press it and it should come ALIVE!
Jul 21, 2014 | Honeywell CT3200 5-2 Day Electronic...
I have a two wire thermostat system. I switched the thermostat from a mercury one to the Honeywell CT3200 with dip switches set for my electric forced air furnace that is 31 years old. The white wire is...
If you look closely at the installation manual page 6&7 it tells you settings to use for your type of system. If I'm not mistaken you will need to back out screw "b" 360°. Hope this helps!
Jun 17, 2017 | Honeywell CT3200 5-2 Day Electronic...
How do I set my thermostat for my furnace? My thermostat wont come on appropriately. I think I pushed wrong buttons and can't get the heat to stay on. Would like to cancel settings and be able to set...
Set the System switch to either Heat or Cool. Press the Hold Temp button. Use the Warmer/Cooler buttons to set temperature. Temps will stay until you either turn off the system switch or press Run Program.  Good luck.
Jan 02, 2010 | Honeywell CT3200 5-2 Day Electronic...
Bat lo flashing periodically
You need to change batteries. The bat lo light flashes when you have about 10% battery life left. Rus
Dec 05, 2009 | Honeywell CT3200 5-2 Day Electronic...
I replaced the batteries in my Honeywell CT3300 and the "Bat Lo" message won't go away even with fresh batteries. Is there a reset button or something?
Per manual do this: System set to Off Remove batterie Replace IN REVERSE POLARITY POSITION or 5-10 seconds Put back in with CORRECT POLARITY Reprogram per sticker on back of thermostat. Done. Just did this myself and it's simple and effective! PaulHaven
Oct 14, 2009 | Honeywell CT3200 5-2 Day Electronic...
I bought a honeywell ct3200 and not sure how to hook it up to a two wire system. The wires coming out wall are black and white
If you just have two wires coming from the wall then attach them to the terminals marked R (may say Rc and or Rh, usually has a jumper installed between the two) and W. Hope this helps
Oct 05, 2009 | Honeywell CT3200 5-2 Day Electronic...
Battery Issue
This worked! Thank you! It was 49 degrees in the house, and now the heater is working again.
Thank you and warm wished for the new year!
Mary
Jun 05, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
336 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
