I have a samsung P1453 washing machine and it refuses to spin, I have checked the obvious like filter and discharge hose,. Is there some sort of sensor to check for load in-balance
  • Anonymous Sep 16, 2008
    I have the exact problem.
Hi i also have a samsung p1453 that will not spin when the digital counter gets to 9 mins remaining it jumps back to 10 mins and wont go through the spin cycle the pump is working fine and emptying as it should cann ot see anything blown on the pcb
any advise woulkd be appreciated
Posted on Sep 28, 2010
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
DOOR IS NOT LOCKED
This video will show you how to open your samsung washing machine P1453 door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2013 | Washing Machines
My washing machine wont wash or spin proprly
the water is not pumping out because you have a blockage in the filter unit which is located at the bottom of your machine or possibly a weak pump. the reason that your machine smells is because the water is not discharging. check the filter first for any blockages, i.e coins, bra wires etc. if that doesn't sort it you may need a new pump
May 12, 2012 | Hotpoint Ultima WF860 Front Load Washer
Samsung p1453 error code 6e?
6e fault is saying that the temperature is not high enough, this is most likely a malfunctioning temperature sensor or an issue inside the electronics.
Mar 10, 2012 | Computers & Internet
Samsung p1453 will not drain or spin
5E (or SE error) is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle.
The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 15, 2011 | Washing Machines
My NEC NFL855 E3 error
E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar).
To Fix:
1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor.
2. Check discharge hose is not crushed or kinked.
3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage.
Jeremy
Jul 19, 2009 | Washing Machines
Debris filter
did you ever find an answer? I am experiencing the same problem :(
Dec 22, 2008 | Washing Machines
MY SAMSUNG P1453 WASHING MACHINE WON'T SPIN
Empty the debris filter at the bottom (take the bottom bit off and turn the dial thingy) There will be water coming out so put towels down.
Aug 25, 2008 | Washing Machines
Washing Machines Logo
627 people viewed this question
Top Washing Machines Experts
