Question about Crosley CR249TA Turntable
How do I remove the platter on my record player? When I lift up on the platter something in the middle is stopping it from going any father.
    Champion:
  • Crosley Expert
  • 271 Answers
Hi, remove the disc in the centre of the platter. Under there you will find a cir clip that holds the platter in place. It may need a light tap on the spindle with a rubber hammer of piece of wood. styluscity@gmail.com
Posted on Sep 13, 2010
How do i remove platter on Beocenter 7007
From the Beocenter 7007 manual:
"If you ever want to remove the platter, lift the record spindle and then insert your fingers under the rim of the platter."
Sep 19, 2014 | Audio Players & Recorders
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
On my record player, the platter is wobbling as it spins and is off balance. what can be done to fix this
Remove the felt on the platter and lift the turning platter of the centre guide pin. Please note where the belt is running, because you will have to place that into the same possition as before. Check for any dirt or debries. Clean out and replace table and belt. Hope this helps
Aug 17, 2010 | ION Audio TTUSB10 Turntable
I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Jul 24, 2010 | Crosley CR248 Turntable
How do I remove the turntable platter on a Ferguson 3047?
Try looking at the spindle where the record hole goes. You might have to lift the mat somehow. There might a C Ring holding it.
Oct 17, 2009 | Audio Players & Recorders
Belt came off on my crosley cr49 record player
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Aug 29, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
The rubber band under the record player has come off
I am not familiar with your particular model of turntable, but typically the belt is easily accessible under the platter (rotating metal disc). Remove the platter (it often just lifts off, but don't force anything) and then you will be free to reattach the belt. Good luck!
Aug 25, 2009 | Panasonic Technics SL-DZ1200 Turntable
Can't remove platter after removing lock washer
It should just lift off, but might be a little stiff.
Jan 04, 2009 | Aiwa PX-E860 Turntable
How to remove platter on Optimus Lab-1100 Turntable
on the shaft in the center where the hole of the record goes there is a locking washer on it . you can carefully remove this with a thin knife of something similar . you may need to use a little force , it is on there pretty tight however it can be removed .good luck
Jul 21, 2008 | Audio Players & Recorders
Won't start
I had the same problem with the arm constantly starting and stopping, and the suggestion above works. Despite, I was a little confused on how to do it. Here's what I did in detail:
- Remove the turntable mat.
- Unhook the belt and remove the turntable platter.
- Once the platter's removed, you should see two plastic white gears in the middle. Rotate the center gear clockwise until its tab hits the larger gear. The center gear should move freely and without resistance until you hit that gear.
- Put the platter back, making sure to re-hook the belt around the spindle.
- Put the mat back.
After that, you should be set!
Jun 04, 2008 | Sony PS-LX250 Turntable
Crosley CR249TA Turntable Logo
834 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
