Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Is there a way to fix an error f51 code myself...like a reset button
  • 15,935 Answers
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Repairclinic com
follow this steps and fix it. God bless you
Error Code
  • Clear the error code and stop the beeping by pressing the "Stop" and "Start" buttons at the same time. Unplug your washer so you can examine the problem.
Function
  • The error code displays because something is wrong with the motor sensor. This can be for a number of reasons. After you clear the code, try washing clothes again and seeing if the error appears. If it does, then you need to take further steps.
Read more: http://www.ehow.com/facts_7565280_kenmore-elite-error-code-f51.html#ixzz2aTwM1Z2u
Jul 29, 2013 | Kenmore 24032\24036 Top Load Washer
My washer wont spin and the add garment light stays on. Then it starts to beep with F51 or FSl (not sure if it is a 5 or an S) shows up. Doesn't do anything more but beep.
Sorry to read about your problem, I hope this helps you out.
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, read below
Basically, the F51 error is a rotor position sensor error.
What has to be fixed?
Two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197). Apparently, Whirlpool has yet to officially recall these parts, but there is a new board that has a reduced or no sensitivity to the rotor sensor and thus the problem should be corrected.
Can I fix it myself?
That depends on your level of handy-skills. If you're one who can work on late model foreign cars with ease, then this probably won't be a challenge. But for most amateur handy-"people" this will require a professional.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 03, 2011 | Whirlpool Cabrio WTW6800W Washer
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Cabrio W10106470 has an F51 code. What
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Konica 7145 F-51-2 Error
Code F51-2 at start-up.
Description:
Solution:
CAUSE: Code F51-2 may be caused by a failed M11 fixing motor. To determine whether or not the motor has failed, use this procedure:
1. Enter the 47 mode (I/O check mode).
2. Input "40".
3. Input multicode "0". If the M11 motor turns, it is good; if it does not turn, the motor has failed.
SOLUTION: Replace the M11 motor (p/n 56AA80072 for 7222/7228/7235 and p/n 56GA73430 for 7145) if it has failed.
hope that help!!!
Oct 29, 2008 | Office Equipment & Supplies
F50 error code and Whirlpool Cabrio
JUST SPOKE WITH WHIRLPOOL ABOUT THE F-50 CODE. THEY SAID THAT THEY ARE AWARE OF THE PROBLEM AND THEY ARE PAYING TO FIX IT. ALSO THE CONTROLL BOARD AND THE RPS SENSOR MUST BE REPLACED TO FIX THE PROBLEM. THE OWNER MUST CALL WHIRLPOOL, NOT THE TECH, TO GET THEM TO PAY FOR IT. HOPE THIS HELPS.
Feb 08, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
172 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
