Question about Dell Inspiron 1300 Notebook
Have a dell inspiron 1300 new battery was off about 2 weeks,plugged back in get slow blinking green light after all night wont come on when i push power button ???
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
My Dell 1300 Inspiron Notebook will not start up, it gets to two green lights but won't go to Four. I cannot get it to start in Safe mode, it will not recognize the command. It does recognize F2 and F12....
Hi petergreenus,
Have you tried draining the power of your system? Please follow the steps below on how to power drain your computer.
1. Turn off the computer.
2. Unplug the power cable from the outlet and remove the battery.
3. Now, press the power button for about 15-20 seconds.
4. Put back the battery in and plug the AC adapter.
5. Press the power button and try to observe the system.
Hope it helps.
Thank you for using FixYa.
Dec 04, 2010 | Dell Inspiron 1300 Notebook
No power leds. My Ac adapter is new with the right voltage coming out. I have to keep on unplugging the power cord then the green light comes on my Dell Inspiron 1300
If the adapter is new or OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 06, 2010 | Dell Inspiron 1300 Notebook
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
May 31, 2009 | Dell Inspiron 1300 Notebook
New battery wont charge
I had the same problem. First, I ordered a non-Dell battery online but battery would not hold charge either - had to send battery back twice but new battery wouldn't work either time. Finally, I resigned myself to ordering one from Dell directly and it's working fine now - so my advice is to bite the bullet and pay more for Dell battery.
Apr 15, 2009 | Dell Inspiron 1300 Notebook
Dell inspiron 1100 wont stay on
Normally the battery light will rapidly flash orange if the battery is defective. It will alternate between orange and green if it is too hot to charge. Or it will either flash orange or be a steady orange if the battery is low or completely discharged. Based on this and the fact that you cannot get it to stay on for more than 7 seconds, I would have to say that you need to recharge the battery by plugging the laptop into an AC outlet. After all, it can't run without the juice.
Apr 14, 2009 | Dell Inspiron 1100 Notebook
Dell inspiron blinking orange battery light. keybrd not respondg
Try this: remove your battery, unplug power, press and hold power button for at least 20 seconds, plug power cord back in but not the battery, press power and see if you get normal boot. If this is the case, your battery probably needs replaced.
Feb 17, 2009 | Dell Inspiron 5160 Notebook
Orange blinking power light on inspiron laptop
I recommend purchasing a new Dell Inspiron battery.
The code 4 blinking orange or amber and one green, means a defective battery.
Thank You, Raphael
Jan 24, 2009 | Dell Inspiron 5160 Notebook
Will not power up
This could be a bad memory chip. Try taking out the memory, putting one or the other in and starting, then changing them out and starting. If it's not a battery or memory, then the problem will most likely be with the motherboard. You will need to take it in for a professional diagnostic in order to find out whether it's a replaceable component on the board or if you will need a new board.
Jul 12, 2008 | Dell Inspiron 1300 Notebook
Dell inspiron 600`
naa dont worry drivers are getting upset ...when ever u get time just recover the sys
May 28, 2008 | Computers & Internet
Dell Inspiron 1300 Notebook Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
