HITACHI 37PD5200 E Plasma dead.
Turned TV off last night by the TV button not standby, tried to turn on this morning dead. Checked mains plug fuse ok.
Suspect power supply fuse which is behind rear cover on power supply board. please can you tell me what rating fuse this might be ?
Many thanks
Carl
  • Ronald Clark Mar 03, 2009
    same as above . Found that the mains fuse in plug blown. Replaced that and then the fuse flashed on power input board.
Do not change fuse if blown as there must be othere issues with power board and you could damage more boards check capacitors for leaks thanks gary
Posted on Sep 19, 2012
    Problem Solver:
  • 61 Answers
The fuse is either open or it will have continuity do you have any standby voltages
Posted on May 15, 2008
  • engeln Dec 11, 2010
    My Hitachi plasma 37PD5200 went dead just over 5 years ago since purchased. I suspected the power board and fault traced that one, problem was found and fixed quite easily. Power Resistor R003 5W 10ohms was brooken (open). No visual indication it was bad, you have to measure it. Replaced that and is back in business again. The Open R003 prevent all the rest of the power board from starting up the relayes RL001 RL002
    Leif
Hitachi LCD TV Dead
There is a internal fuse on the power supply board. When you plug in the set, does the standby light come on?
May 10, 2013 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
42hdt79 Hitachi TV will not power up. Cord is good TV is dead ??
Try the button on the front bottom, under the power button on the front.
Apr 05, 2009 | Hitachi 42HDT79 42 in. Plasma Television
No power to my Hitachi 42Pd6600 plasma tv
the master switch at the bottome of the TV per Brianbuy solved my problem...Thank you!
Jan 20, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
No power
First off I did not see make or model. When plasmas die you have failure in either the power supply of the sustain boards. Do you have any voltage readings from va or vs ?
Craig www.classtorations.com
Jun 08, 2008 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
Hitachi pd7200 42" plasma
unplug. leave off for a few minutes. small chance it will reset.
also, it might have lost its input setting and is no longer looking at the input you send the source signal to.
good luck
mark
Dec 02, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
No power when power button is pressed
I would have to say you have a dead power supply. You will want to make sure first that the "MAIN" power switch located on the lower left on the rear of the unit is turned on as well. Without that on there will be NO standby light.
Apr 17, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
624 people viewed this question
Top Televison & Video Experts
Electro Med Services...
