Advent 9117 battery not holding charge, wont charge up with charger
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 18, 2010
Battery not holding charge and power lead has to be held in position for charging to take place
Use an ESD wrist strap with it's alligator clip attached to a good ground source.
Remove ALL power. Remove the AC adapter (Charger) and Battery.
Disassemble the laptop, remove the motherboard.
Replace the DC Power Jack. http://www.laptopdcjack.co.uk/product/Advent_6411_DC_Power_Jack_Socket_DC-ADV-6411
Information that may help to disassemble,
http://www.adventsupport.com/viewtopic.php?f=1&t=6770
http://www.uktsupport.co.uk/advent/laptop/6411v.htm
ftp://ftp.packardbell.com/pub/itemnr/7602080000/Disassembly_EasyNote_MZ_rev_100.pdf
(Advent 7211 series is like a P.B. MZ35 series. Just thought it may help)
http://www.youtube.com/watch?v=Im_n9K-14_I
Regards,
joecoolvette
Nov 25, 2012 | Advent Computers & Internet
Advent 100 roma only works on battery not on dc charger
try another charger ,,, then check the power plug ( could be broken or needs re-soldering ) .... after you try all of that and didn't work that means you need to replace the power ic ...
Mar 06, 2012 | Computers & Internet
I bought a new battery for my advent 4490 net book .the battery worked fine on the initial charged tht it already had but now whn the battery is now left with the 9% charge in it , i plug in my charger and...
I I have the same issue and i took my netbook to more than 4 electronic engineers, all of them said that doesnt seem there is a problem in my netbook though.
Mar 31, 2011 | Advent Netbook
Advent 9117 laptop wont boot up
well it looks like you had a phisical problem with the harddrive that made the data to be unreadable the only thing you can do is to try to reinstalll the operating sistem and if it doesent work try to replace the harddrive
Mar 11, 2010 | Computers & Internet
I have an Advent 9117 which I have to remove the power lead from and un-plug the battery, then JUST re-plug the battery in to get it to start. ANY ideas?
This can happen if the power adapter is failing. Try using a different power adapter and see if the problem is still there.
Feb 23, 2010 | Advent Netbook
I have an advent 8315 thta will not charge up. don't know if it is the charger or battery pack. Any advice as to where to get a cheap replacement.
Can get universal power supplies for about a tenner on ebay.If it wont charge but runs on mains it will prob be the battery
Jan 19, 2010 | Advent Netbook
I left the battery in whilr replacing the screen
remove battery.
plug in the power supply cord.
restart computer.
shutdown computer.
replace battery.
restart computer.
Oct 25, 2009 | Advent Netbook
Manual
According to UKT support this is a rebadged Uniwill L75118
http://www.uktsupport.co.uk/advent/laptop/9117.htm
Gives a general spec sheet.
http://www.uniwill.com/UserDownload/l75ii/l75ii.php
Has a download for the pdf manual at the bottom.
I have one too and am busily trying to find out if I can upgrade the Processor.
According to the manual it is possible to have a t5700 2.2GHz processor in it.
dr_dazzit@yahoo.co.uk
Mar 16, 2008 | Recoton Advent Advent Q2035A 20" TV
Computers & Internet Logo
172 people viewed this question
David Payne
David Payne
