Question about Fasco Staple Gun Pneumatic F3c Atw-38 Mod Range
My fasco staple gun will not shoot out the staples only air
SOURCE: (DP) air staple gun won't reload after shooting 1 staple
i have mini blow 8 mm gun automatic after i chut he did not reloaded plz tell how i can fixed
Posted on Jun 28, 2009
  • 6 Answers
SOURCE: gun shoots but no staples coming out, part that
try carefully tapping it in with a nail punch and hydraulic tool oil
Posted on May 18, 2010
SOURCE: I have an older Fasco stapler, it is orange in
Some models have small screws on the face plate that can be unscrewed to release pressure or a spring clip to release. You can also push the plunger back into stapler with a thin narrow srewdriver, the staple may fall out.
Posted on Nov 30, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I need the driver for
Hi Ron and Welcome to FixYa, I am Kelly.
This appears to be the item your looking for:
http://www.airnailerparts.com/servlet/the-1528/FASCO-F21T-92-STAPLER/Detail
The re-build kit is here:
http://www.airnailerparts.com/servlet/the-1287/FASCO-F21-STAPLER-%26/Detail
Phone support for your Staple gun is here: (Not toll free)
Phone at (906) 337-1278
email: newyooperworkshop@yahoo.com
Thanks for choosing FixYa,
Kelly
Posted on Mar 06, 2011
  • 13 Answers
SOURCE: I need a part for
Galino.com should be able to get you a parts diagram and supply the part
Posted on Mar 14, 2011
After ejecting five staples, my staple gun stopped pulling staples into the feed and ejecting them. It makes the shooting sound, but nothing comes out. I examined it for staple jam, but found nothing.
staple guns are feed from the rear by a spring. check and see that the spring is still douing its job. if this isa air feed,inpact gunn, clean ejector ports and staple slide.
Apr 26, 2017 | Staples Tools & Hardware - Others
What should I do if my brand new Fasco pneumatic upholstery stapler is leaking air through the tail end...not the hose, but the two holes in the handle? Any suggestions?
Hi Anonymus,
What's happened if the driver blade has stopped in mid stroke, the air will escape. Quickest was 'round this is to take the airline off the tool, then find some scrap wood, place the tool on it as though you're firing it, and in THIS ORDER... pull the trigger and re-connect the airline at the same time. This usually sorts this out. Regardless of the tool make and model this will happen to most users sometime....
Leigh Co Limited
May 25, 2014 | Fasco Tools & Hardware - Others
I have a Fasco F1B7C-16 upholstery stapler that won't shoot. There's no mechanism to push the staples forward -- is that normal? The instructions are completely useless ... Help!
The staples are loaded in from the bottom of the unit.
Pull out the staple tray all the way to the rear then turn the unit upside down and drop the new staples into the grove in the unit.
Push the tray back into the unit and you are ready to go!
Dec 03, 2011 | Fasco Tools & Hardware - Others
Staple jams by driver blade in gun and I have to dismantle nose to get it out. Empire Rainco 7-16.
The problem is wear on the sides of the driver blade. With the constant up/down movement of the driver against either side of the nose plate, it eventually narrows enough to allow part of the fine wire 71 series staple to find it's way between the driver blade and the inside wall of the nose plate. A new driver blade cures this completely. Rainco tackers have become a bit rare but the good news is, they're actually manufactured by Fasco and the Fasco driver fits into the Rainco piston by the removal of a single pin to allow the old blade out, replace with the new Fasco blade, re-insert the pin into the piston, then re-assemble the gun and you're away.
Mar 06, 2011 | Nailers Empire Rainco R16 Stapler Driver...
I have rebuilt my staple gun all new seals new piston and driver blade new bumper cushen when gun shoots the blade wont retract up all the way you have to open the staple mag. fire the gun then the blade...
Inside the cap, there's a plastic circular insert. It's a common mistake to reassemble the gun with this cap spacer upside down, resulting in the top of the cylinder not sealing in the air that returns the piston. Simply undo the cap, turn the spacer over and screw it back on again. Done.
Feb 27, 2011 | Fasco Tools & Hardware - Others
I have a F3C.NC-40/50 staple gun I need replacement parts for. who sells parts for F?asco nailers
www.galino.com are a UK Fasco distributor and should be able to supply F3C parts
Jan 28, 2011 | Fasco Tools & Hardware - Others
I have an older Fasco stapler, it is orange in color. S3G 16 is number on it. The part that pushes out the staple has a piece of staple stuck in it. How can I get this out?
Nov 30, 2010 | Fasco 9 Narrow Crown Pneumatic Staple Gun
Schematics on fasco air stapler #F1B 7C-16
I can e-mail you schematics. I have all Fasco & Rainco parts for this tool and more in stock!
Aug 10, 2009 | Fasco Staple Gun Pneumatic F3c Atw-38 Mod...
Jun 06, 2009 | Staples Tools & Hardware - Others
Fasco Staple Gun Pneumatic F3c Atw-38 Mod Range Logo
94 people viewed this question
Top Fasco Tools & Hardware - Others Experts
yoopertech
ray gallant
Tom Chichester
Are you a Fasco Tool and Hardware - Other Expert? Answer questions, earn points and help others
