Question about Dell XPS M1530 Notebook
How do you eject a cd from the drive - Dell XPS M1530 Notebook
  • 2,567 Answers
1. Shut down the laptop.
2. Straighten a paper clip.
3. Gently push one end of the paper clip into the small hole in the front panel of the CD/DVD drive till it hits the plastic arm which releases the CD/DVD door.
4. The CD/DVD will eject.
Posted on Sep 18, 2010
My dvd tray is not ejecting,i cannot insert a cd
CD Drive Tray problems
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Feb 05, 2013 | Computers & Internet
Tip
Cdrom drive can not eject / Cdrom is stuck
How To Eject CD from CD-ROM drive if it is Stuck :
If you have a CD into CD-ROM drive and it is stuck and you are trying to eject tray of CDROM by pressing the eject button or windows eject command but CD won't eject as there is no command to eject a stuck compact disc from the CDROM drive then this article is for you.
Step 1: Switch off the computer.
5573fa0.jpgStep 2. On the front of the CD-ROM drive you may find a small hole called Emergency Eject hole below the tray of CD-ROM drive . Take a long pin around 3 inch, (also known as CD ejector) it must be hard enough, insert this pin inside the hole and push a little. The CD tray will slightly move to out.
Step 3: Now you may manually pull the tray and you are done. You have successfully ejected the stucked CD.
Step 4: Switch on the computer and you may work as usual.
Thanks
Proton
on May 12, 2010 | Computers & Internet
Instructions on how to eject a cd from vostro 1510 ? william@kanigan.com
You can eject a CD in two ways!
1 Simply pressing the button on the right edge of CD drive and drive opens by sliding out
2. Clicking on my computer which shows all the drives C: D: E: etc. C: is hard drive so can not be ejected. Right click on the D or E where ever the CD is and choose eject! That will open the CD drive!
Sep 08, 2011 | Dell Computers & Internet
Cd drive wont eject
Try ejecting it through "My Computer". Right click on the drive and select "eject". If you can't locate the drive, then it's probably missing the driver.
Nov 25, 2010 | Sony VAIO VGN-NS240E/W Notebook
Eject does not open
Most hard-drives do *NOT* have an EJECT button.
Most diskette-drives *DO* have an EJECT buttton.
Most CD/DVD-drives *DO* have an EJECT button.
Turn your computer off. Straighten one end of a Norwegian paper-clip, and insert it into the small hole in the front-plate of the CD/DVD drive, until you feel "resistance". Then, push it another 1/4 inch, and the drive-tray should "unlock" and open slightly. Then, gently pull the tray fully-open. Remove any CD/DVD media. Then, replace the CD/DVD drive.
Jan 29, 2010 | Computers & Internet
My dvd drive wont eject since i ripped cd's on windows media player it froze and then wouldnt eject te cd
well on the CD drive u will find a pin hole which is used to eject the drive tray manually so use a pin and try to eject the CD.
good luck
Jan 05, 2010 | Acer (KV.16X04.007) DVD Drive
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Eject Problem..
1. right click on the drive. 2. press 'Eject' option. this will intern send the software interrupt to the drive to open it, if your cd-drive 'button' is not working. thanks.
Jun 08, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Cd rom will not eject
On the eject tray of the cd/dvd drive you will see a small pinhole use a pin and insert into that, the cd drive would eject, ITS A MANUAL EMERGENCY EXIT BUTTON ON ALL CD/DVD DRIVES, INCASE THE CD DRIVE DOESNT EJECT normally as your case here
Aug 27, 2008 | Dell Dimension C521 PC Desktop
Dell XPS M1530 Notebook Logo
129 people viewed this question
Alun Cox
