Question about Whirlpool Dryers
Dryer is squealing, could it be drum support rollers? If so how do you install them?
    President:
  • 3,074 Answers
You will need to pull off the front panel, unscrew the screws inside of the door frame of the dryer door, gently pry up with a screw driver on the top two corners, disconnect door switch, sit panel aside, lift up on the top it should stay up, note the positioning of the belt as you will need to remove it in oreder to take the drum out, remove belt, lift up and out on the drum, the rollers are up against the back of the dryer. Hope this helped tim
Posted on Sep 12, 2010
    Habit-Forming:
  • 84 Answers
They usually just need oil,once you take it apart you will know.where your lint screen is on top,there is 2 screws,take them off,now with a straight screwdriver,place under the lid,it should pop up,the lid will lift,looking on the inside panel you will find another 2 screws,remove them and the front panel should remove while lifting
My dryer won't spin and is squeeling
It sounds like either the belt is loose or the drum is frozen. Try the following links to see if they help.
Appliance411 Home Service Appliance Repair Manual for Whirlpool Kenmore...
This will help if you have never repaired a dryer.
User Manual Downloads
Feb 05, 2016 | Kenmore HE2 6.7 cu. ft. Gas Super Capacity...
Kenmore solid state dryer. was squealing while running. now drum stops and starts. still squeals
belt, idler pulley, drum glide/rollers:
belt/idler pulley:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
rollers/glides:
http://www.partselect.com/dryer+replace-glides+repair.htm
belt configuration
http://www.applianceaid.com/images/belt-config.JPG
Dec 03, 2010 | Kenmore Dryers
Whirlpool Dryer squeals
Either the drum is rubbing against something or more likely the belt pulley is cause the noise. Oil the pulley wheel and the drum rollers and it should stop squealing.
Dec 14, 2009 | Dryers
I have a dryer that is making squeal as the
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 11, 2009 | Dryers
I have a maytag performa dryer model #pdet920ayw and when i turn it on it squeels.
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
The most common cause of a squeal is the drum roller, of which there are 2. It is usually a good idea to replace both rollers, roller shafts and drum belt at the same time, as they have a tendency to wear at the same rate. You must also use the proper lubricant on the roller shafts, (Syl-Glide), or you will have a recurrence of the squeal.
1. Drum Roller Image
http://www.repairclinic.com/SSPartDetail.aspx?s=t-pdet920ayw-%3d%3di966673&PartID=966673
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
You can also obtain more appliance information at my website, www.homemanagement.services.officelive.com
Aug 27, 2009 | Maytag Dryers
Sqealing
If your dryer is noisy, check these: Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
May 12, 2009 | Dryers
Kenmore series 70 dryer gas model 76712693-76712 squealing
Raise the top.
Remove the front panel.
Remove the drum.
Remove and replace the drum rollers and the belt tension roller.
Jan 20, 2009 | Kenmore 72982 Gas Dryer
When I turn my may tag dryer on it squeals. We tried lubricating the mechanics then the drum stops turning. We then degreased it, hand spun the drum and it resumed working.
Squeals will usually come from the rollers that hold the drum or the one that puts tension on the belt. Also, check the front of the drum where it meets the front of the dryer. There may be some teflon pads worn out. The rollers can be lubricated for a short term fix but should be replaced.
Dec 16, 2008 | Dryers
Dryers Logo
35 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
