Question about Linksys Wireless-N WRT150N Router
Lynksis wrt150n .. setting
I just bought 2day new WRT 150N Lynksis wirless router. I follow the step for lan and changed the name and password as directed while using cd rom. I am not able make my network secured. its showing unsecured. Also not able to know how get the administrative tab which mention in this web.
Please help.
  • 47 Answers
Log in to your router and select the wireless tab. Then click on wireless security. Set your security mode, encryption type and create a key that will be needed to connect to the router wirelessly. Administration tab should be right next to status tab.
Posted on May 14, 2008
I have a linksys wrt 150n router. i've connected my imac wirelessly, but cannot get my pc-laptop to connect. what am i doing wrong? yes, it is secured with a password.
hi parkerjunkma,
be sure you detected the wrt..then the SSID and Security Encryption should be matched..the SSID will definitely detected so the Password should be entered.
mastergani
Dec 28, 2010 | Linksys Wireless-N WRT150N Router
Router does not show wireless light. I have reset it but can't access it with the setup wizard. Any suggestions?
* NOTE: If you tried to set-up the WRT-150N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
then do this :
1. Hook up the Linksys WRT-150N Router to the Modem via a LAN cable.
2. Hook up the Linksys WRT-150N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-150N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-150N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-150N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys Wireless-N WRT150N Router
I have a zhone 6211-I3-200-ADSL2+CPE w/phone filter. I am trying to connect 2 computers (1 laptop, 1 desk top) to a linksys WRT 150n wireless router and cannot get the wireless connection to work. It shows...
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Aug 03, 2010 | Zhone 6211-I3-200 Router
I NEED TO KNOW HOW TO SECURE MY LYNKSIS WRT150N
To secure your router wireless signal Your Wireless signal may already be secured by the manufacturer and often the wireless code is printed on a label stuck to the router itself
IF not already set here is how you secure the wireless Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - enter the Router’s default IP address, 192.168.1.1, in the Address field. Press the Enter key. A screen will appear asking you for your User name and Password. Leave the User Name field blank. Enter admin in the Password field. Then click the OK button.
Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password.
On the PC Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
Apr 13, 2010 | Linksys Wireless-N WRT150N Router
How do i secure my linksys WRT 150N?
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 09, 2009 | Linksys Wireless-N WRT150N Router
How to secure N WRT 150N Router
enable wep or wpa or wpa2 encryption in the wireless settings.
Nov 04, 2009 | Linksys Wireless-N WRT150N Router
I cant connect a new laptop to my 150n router. i also forgot my password
For you to resolve this problem, please follow the following steps:
(1) Press and hold the reset button for 5 seconds.
(2) You would be prompted to input a username and password, use this default on both fields "admin". Just input admin on both fields and click enter.
This would rectify the problem.
Good Luck.
Oct 13, 2009 | Linksys Wireless-N WRT150N Router
I have a WRT 150N wireless router. it is not putting out a network but i can connect to the internet with one of the lan line ports
Connect to the router via the admin screen and select the wireless tab. Check to see if wireless is set to disable or to a setting that is not compatable with your PC/laptop wireless card.
Hope that helps and thanks for using FixYa
Mar 07, 2009 | Linksys Wireless-N WRT150N Router
Wrt 150n
OK maybe get an external antenna in any event place the Unit/Antenna up as high as possible... also ensure ya aren't near any large metal objects/power wire junctions etc, but generally an external antenna will Boost ya signal, also even just moving "it" somewhere else can make a big improvement... In some wifi routers ya can increase and decrease ya output, ya may wanna check ya manual to see if yours is one of those? Ya may also want to try changing "Channels" on the Router too.. this also has been known to help. Good Luck :)
Feb 08, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
192 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
