Question about Microwave Ovens
I have an over the stove Jenn air microwave. I was making jam--using all burners on high heat for several hours. We were using the timers on the micro..In the midst of the operation the microwave went dead. At first I hoped that the heat may have triggered a shut off valve...no such luck. It is dead. The repairman came out, took it away, said that it needed a $185 "board." The cost will be over $250 to repair. My question is: could this happen again whenever I have a long term, high heat procedure. I considered replacing the thing but all my appliances are Jenn air (they were there when I moved in 2 yrs. ago) and it fits in the space. This microwave was made in 2005. I am a single semi retired woman so it doesn't receive alot of use. I appreciate any suggestions or words of wisdom that you can provide.
  • 160 Answers
For electronics, as with most most other types of machines, heat is the enemy.
The circuit boards in a microwave are mounted directly behind the bottom cover, and if the air below he machine is extremely hot, the board's components will slowly cook until they break down.
Assuming that the replacement is mounted in the same place, then your answer is: Yes, it can and most likely will happen again, given the same circumstances.
I see 2 logical options to help save the microwave;
The first is to block the heat, by adding a heat-shield under the microwave.
There are a few presentable models on the market, and they're just a simple aluminum diffuser with a thin layer of insulation behind it.
The second is to redirect the heat, by setting a small fan on the counter next to the stove (just a few inches taller than the pots on the burners) that will push the rising heat away from your microwave.
The 'fan plan' is an old-school quick-fix that you can pull out when you need it, and will work fine while you shop/hunt for a proper heat-shield that fits your decor.
***Don't forget to VOTE for the guys who take an interest in helping!
Posted on Sep 12, 2010
Testimonial: "what a treat to have a response and solution. Thank you for the information--my next purchase--after repairing the microwave--will be a fan!"
Heating problems Jenn-air microwave - jmv8000bds - it heats while unused for a while but to warm more than the first item is not working - what is broke? jeffrey40@yahoo.com
First, check to make sure that the air vents are clear. Secondly, is the cooling fan running? If these are OK, (how old is this unit?) it's probably the magnetron is old and weak....... Put in a container with 2 quarts of cold water and run it for 10 minutes. It should boil water after about 4 or 5 minutes and keep boiling it for the remainder of the timer preset. If not, the magnetron is losing power.
Sep 20, 2013 | Jenn-Air JMC8130DD Microwave Oven
Ihave a Jenn-Air JMV8196 microwave oven. The clock works,the fan works and the light works. Not sure why the microwave will not come on to cook. Help?
The problem is caused by one of three things, the magnetron "heats food" the high voltage diode "sometimes shorts" or the high voltage capacitor " shorts"
Mar 10, 2012 | Jenn-Air JMV8196 Microwave Oven
I have jenn-air microwave oven model m167. Unit will come on and all programming works to heat food. Oven acts as if it is heating food,however it does not cook or heat food items. Any help with...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 28, 2010 | Jenn-Air JMC7000 Microwave Oven
I have a jenn-air stove The igniter went out on all 4 eyes on the cook-top
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Dec 25, 2010 | Microwave Ovens
My Jenn-Air microwave JMV8208AAS will not heat the food and when turn on it makes a loud humming sound.
This is most likely the magnetron, the high voltage capacitor, or the power diode.
For an explanation on how these things are repaired, check out this website.
http://www.partselect.com/microwave+no-heat+repair.htm
If all else fails, call an Appliance Repair Technician.
Dec 09, 2010 | Jenn-Air JMV8208AAS Microwave Oven
My Jenn-Air microwave turns on, and runs the cycle, but is not cooking the food. any hints?
If everything works but the heat, its probably a blown thermal fuse, could be blown fuse for the HV transformer, bad connection to magnetron filament, or several other things. You will have to take the microwave apart, several screws around the cabinet make sure you know where each screw goes back because they all may not be the same. andbe very careful even with it unplugged there is high voltage present at the capacitor.
Aug 30, 2009 | Microwave Ovens
My refrigerator stopped working and will not come back on. It is a Jenn-Air Side by side purchased 4 years ago.
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Microwave Ovens
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn Air Microwave won't cook
I had the same problem with mine wich is the same built in Jenn Air jmc7000 after using an ohm meter to check some of the switches I discovered the door swith was bad replace it for about 5 dollars and it works as good as new...Good Luck
Jan 04, 2009 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
60 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
