Question about Sony Playstation 3 (PS3) Console
When I cut my p3 on it comes on the indicator turn green 2 yellow then off, it does all this n 12 seconds
  • 225 Answers
Yes this is the yellow light of death or red light and it is caused by heat build up internally you will need to stop this heat in order to play again and you can use a good repair guide or you can send it in for a fix.
Posted on Sep 12, 2010
Yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Tip
Fuse list ford contour
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses Rating Color Circuit
Engine bay fuse box
1 80 Black Power supply to main fuse box
2 60 Yellow Radiator fan
3 60 Yellow ABS
4 20 Yellow Daytime running lights
5 30 Light green Fog lamp
6 30 Light green Not used
7 30 Light green ABS
8 30 Light green Air pump
9 20 Light bue PCM module
10 20 Light bue Ignition switch
11 3 Violet PCM memory
12 15 Light bue Horn & hazard flasher
13 15 Light bue Oxygen sensor
14 15 Light bue Fuel pump
15 10 Red Right-hand low beam
Passenger compartment fuse box
16 10 Red Left-hand low beam
17 10 Red Right-hand high beam
18 10 Red Left-hand high beam
19 7.5 Brown Heated door mirrors
20 10 Black Windshield wipers
21 30 Light green Electric windows
22 7.5 Brown ABS
23 15 Light bue Reverse lights
24 15 Light bue Brake lights
25 20 Yellow Door locks
26 20 Yellow Main light
27 15 Light bue Cigarette lighter
28 30 Light green Power seats
29 30 Light green Heated rear window
30 7.5 Brown Engine management
31 7.5 Brown Instrument pannel lights
32 7.5 Brown Radio
33 7.5 Brown Front and rear sidelights (left)
34 7.5 Brown Interior lighting & clock
35 7.5 Brown Front and rear sidelights (right)
36 30 Light green Air bag
37 30 Light green Heated blower
38 Unused
Relays Color Circuit Location
Engine bay fuse box
R1 Green Daytime running lights (Canada)
R2 Black Radiator fan (high speed)
R3 Blue AC cut-out
R4 Brown AC clutch
R5 Dark green Radiator fan (low speed)
R6 Yellow Starter
R7 Brown Horns
R8 Brown Fuel pump
R9 White Low beam headlights
R10 White High beam headlights
R11 Brown PCM power supply
R12 White Interior and courtesy lights
R13 Yellow Heated rear window
R14 Yellow Heated blower
R15 Green Windshield wiper motor
R16 Black Ignition
R17 Unused
R18 Black One touch window switch Driver's door
R19 Blue Cruise control cut-off Central fuse box bracket
R20 Unused
R21 Unused
R22 White Fog lights Interface module bracket
R23 Black Turn signals Steering column
R24 White Left-hand flasher Door lock module bracket
R25 White Right-hand flasher Door lock module bracket
R26 Unused
Bulbs / Lights Wattage Type
Low beam headlamp 55 9006 Halogen
High beam headlamp 55 9005 Halogen
Parking / Side light 5 2357A Wedge
Front turn signal 21 2357A Bayonet
Rear turn signal 21 1157 Bayonet
Tail light 21 1157 Bayonet
Stop light 21 1157 Bayonet
High mount stop light 5 2723 Bayonet
Fog/Driving light 55 893 Halogen
License plate 5 6418 Festoon
Reverse light 21 1156 Bayonet
Front sidemarker 5 2357A Wedge
Glove box
Map light 5 64111 Wedge
Dome light 10 6411 Feston
Step/Courtesy light
Trunk/Cargo area
Engine compartment 10 89 Wedge
Instrument-general
Automatic trans indicator
on Apr 15, 2015 | Ford Contour Cars & Trucks
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Furnace fires but cuts out after 10 seconds. Yellow lite flashing 2 times continuous. Green light flickers and sfter furnace cuts out gos bright green for 2 seconds and then goes back to flickering.
Since you didnt include Brand and Model number, you could check on the inside of'
the front panel you take off to access the furnace. Most have a diagram of the wiring
and will have an Problem Code list that tells you what those flashing lights indicate.
Good luck and feel free to reply with Brand and Model #
Mar 31, 2011 | Heating & Cooling
Just put new batterys in safe . but safe will not stop bleeping what is the problem
Please follow these steps
Programming a user code
There are two ways to program a user code.
A 1. Press the Program key.
2. Enter the Factory Code. The green LED remains ON
while you enter the 5-digit user code of your choice.
After 5 digits are entered the green LED turns OFF.
(To enter a new User Code, repeat these steps.)
B 1. Press the red button inside the safe. The lock will
beep and the green LED will come on.
2. Enter a 5-digit user code.
Keep your new user code secure.
For your records, please copy it here:
____ ____ ____ ____ ____
Programming a password
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Battery replacement
Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To
reestablish your Password, follow the directions above under
Programming a Password.
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four bit key to the right.
5. Open the door.
Signals
Your electronic-lock safe communicates by means of several
audio/visual signals.
Red (Error) LED + three beeps indicates
one of the following:
1. You have pressed Program key out of sequence
2. You have entered an invalid code or password.
3. You have let 5 seconds or more elapse between key entries.
Green (Proceed) LED + single beep occurs
1. After entering each digit of Factory or User Code, or
Password
2. After pressing Clear key
3. After pressing Program key
Green LED only
1. Comes on after you enter a valid code/password and
remains lit during the 4-second period in which the safe
can be opened.
2. Comes ON in the Program User Code mode after you enter
the Factory Code and remains lit until you have finished
entering a 5-digit User Code.
3. Comes ON in the Program Password mode after you have
entered your User Code and remains ON until you have
entered a 5-digit password.
Yellow LED
Indicates low battery and will typically not turn ON until
battery has been in use approximately two years or longer.
Your electronic lock automatically performs a low battery test
during each lock use.
If a �low battery� condition is detected the Yellow LED will
come ON and remain ON during each subsequent lock
operation. (The lock will continue to function in a Low Battery
state, until battery failure.) The Yellow LED will turn OFF only
after three consecutive Good Battery readings or after the low
batteries are replaced. (Note: If the new batteries are installed
in less than 60 seconds the Yellow LED may come ON and stay
ON during the first lock operation before it returns to OFF.)
NOTE: It is recommended you replace the batteries after two
years, or when the yellow LED remains on.
Jan 09, 2011 | Safe International Electronic Digital Safe...
Canon i470D Printer will not work. Yellow light
1. Turn off the printer ( "Power" button).
2. Hold the button "Resume", include printer (click "Power").
3. Hold the "Power" button, release the button "Resume" (power indicator / preparedness must turns green)
4. Not releasing the "Power" button, double click "Resume" and release both buttons
-- each time you click "Resume" power indicator / willingness to change color (one-click - yellow, the second hitting - green). U printers with more than one indicator - indication switches (power indicator / preparedness - green indicator error - yellow)
-- after the buttons are released, power indicator / preparedness will be for some time to blink green (Stamford time depends on the printer model), and then the green light permanently
-- If after these actions instead of constantly burning green printer continues to display error, or you are mistaken in paragraphs 1-4 (turn off the printer and repeat with paragraph 1), or if additional printer error that must be corrected, or it will not go down to a service mode.
5. Four times click "Resume" (each time you click "Resume" power indicator / willingness to change color, and the printers with more than one indicator - indication switches: the willingness / error).
6. Once you click "Power" to confirm the selected action (reset counter absorber). To disable the printer "Power" button to click again.
For some printers (for example, iP2000) to switch off clicking "Power" again, that is three in a row.
May 08, 2010 | Canon i 470D InkJet Printer
Im lookin fer the radio wiring diagram for my 1996 geo prizm because someone cut the standard clip for the stock radio out
Under the center console/dash you should has two connectors.
LARGER CONNECTOR
A Right Front Speaker (+) Green Gray
B Left Front Speaker (+) Pink White
C Right Front Speaker (-) Blue Gray w/ Black Stripe
D Left Front Speaker (-) Purple White w/ Black Stripe
E Ground Wire Black Black
F +12 Volt Ignition Wire Gray Red
G Power Antenna Wire 1 Blue (join wires 1 & 2
H Power Antenna Wire 2 together to this blue wire)
I Do Not Use
SMALLER CONNECTOR
J Right Rear Speaker (+) Red Purple
K Right Rear Speaker (-) White Purple w/ Black Stripe
L +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow
M Left Rear Speaker (+) Black Green
N Left Rear Speaker (-) Yellow Green w/ Black Stripe
Dec 02, 2009 | 1996 Geo Prizm
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Playstation won't stay turned on
THEY SYSTEM SOUNDS AS IF THE HDD FAILED THE 60GIG VERSION DOES THIS ALOT CONTACT SONY AT 1800-345-7669
Jan 22, 2009 | Sony Playstation 3 (PS3) Console
Stereo wiring diagram
2000 Hyundai Elantra Stereo Wiring Constant 12V+ Light Green Switched 12V+ Brown Ground Black Illumination Dark Green/White Dimmer Dark Green/Black Antenna Left Rear Front Speakers 5 1/4" Doors Left Front (+) Green/Red Left Front (-) Light Green/White Right Front (+) Red/Blue Right Front (-) Light Green/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Yellow/White Left Rear (-) Yellow/Blue Right Rear (+) Green Right Rear (-) Green/Blue
Jul 29, 2008 | Hyundai Elantra Cars & Trucks
Sony Playstation 3 (PS3) Console Logo
14 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
