Will not fill with water, water runs for a short while then shuts off and shows F 20
  • vinnyrueda1 Sep 12, 2010
    sensor is shorting out
  • 15,935 Answers
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) – with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
My maytag quite series 100 _ fills with water starts running cycle but stops after about 20 sec _ it does this 3 times then shuts completely off
Sounds like the timer could be a issue . or motor running to hot clean all under and behind make sure no dust ..UNPLUG UNIT FIRST ,....
Sep 28, 2015 | Maytag Washing Machines
Ive replaced 3 toilet fill valve with 440a Fluid master fill valves height is good water level good.After a while it sounds like there is leak by from all toilet.Flappers have been replaced. What coul
check the overflow pipe in the cistern tank as some fill valves do not stop completely but allow input of water after the noise has stopped. This allows the water level to rise up and the water to flow out into the toilet bowl. Reduce the water level height by adjusting the cut off level and when the water rises past the new level the increase pressure on the valve will shut it off.
Sep 16, 2014 | Fluidmaster 400A Toilet Tank Repair Fill...
Dishwasher malfunction
follow this steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board.
Jul 08, 2013 | Dishwashers
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
The washer will start a load of laundry then about 1/2 way through the cycle shuts off and LF show where the time is shown for the load to be finished, this does not matter what size or type of load is...
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Please rate my solution if it was at all helpful.
Thanks, Repairman45.
Dec 17, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F 20 Error code washer won't fill up.
http://www.fixya.com/support/r3608632-f20_error_code
Jun 03, 2010 | Kenmore Elite 45986 Front Load Washer
WATER TO ICEMAKER
The icemaker inlet valve is stuck, or the solenoid that controls the icemaker is shorted. both parts must be tested.
Mar 29, 2009 | GE GSS25JFM Side by Side Refrigerator
GE Nautilus 4800 Dishwasher/Shuts off/ No water draining out
It may be the motor start capacitor or the motor or the wiring to it. Some units have a built-in switch that shuts the unit off if the motor doesn't start turning after a short interval. However, if it drains it usually means the motor runs enough to pump it out. These units usually stop draining when the fill switch opens at the lower level.
Nov 29, 2007 | GE Nautilus 24" Built-in Dishwasher
Kenmore Elite Calypso
FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. This could just be a fluke, or you could have a possible bad pressure switch that is not shutting off the water supply correctly. In addition, fill valves have been known to short out causing water to constantly fill in the wash tub. Lastly, your household water pressure could be too low and won't shut the fill valves off properly. Inlet water pressure should be a minimum of 10-20 psi. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display. I hope some of this leads you in the right direction.
May 12, 2007 | Kenmore Elite 21086
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
