Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
My shark steam mop has stop producing the steam to clean. I only get a little water to come out to wet the cleaning pad. Is it stopped up and if so how do I get the steam and water flow back
  • 3 Answers
Dear Sir/Madam
Good day.
We're Auto-parts manufacturer from China. We are able to supply Axles & Axle tubes , Grease Nipple,Brake hose , Auto Springs, and some other fittings. If you have any requirements about auto-parts , please feel free to contact us.
Our link:http://www.jdk-autoparts.com/en/index.php
Thank you for reading.
Best regards
Maxine
E:zjhuisen@163.com
Posted on Dec 12, 2013
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
7
Posted on Sep 24, 2010
Mop turns on but will not produce steam, how can I fix this ?
SOLVED: How to Fix a Broken Shark Steam Mop - YouTube
? 3:24
www.youtube.com/watch?v=Vz8OvV30sHMMar 20, 2013 - Uploaded by ProvenHelper I never used distilled water in my Shark Steam Mop and after a few years, my steam mop stopped producing ...
Oct 14, 2015 | Shark S3101 Euro Pro Steam Mop
Shark Euro Pro Steamer
Hi, you could try the following steps, if you have not done so already. Some of these steps may seem like common sense, but it's for people to forget about checking the least expensive part to replace first, so if some of the steps are those that you have already tried, then feel free just to skip through to the ones you have not tried already.
  1. 1
    Make sure the power cord is plugged firmly into the outlet. The steam mop will not start if it the power cord is loose.
  2. 2
    Check the fuse box or circuit breaker connected to the outlet the steam mop is plugged in to. Replace any blown fuses. Reset any tripped breakers.
  3. 3
    Check the water tank if the Shark steam mop will not produce steam. Add water to the tank if it is empty. The mop will not make steam without water in the tank. To fill the tank, turn the tank cap counterclockwise and lift it up to remove it. Set the filling funnel into the tank opening. Pour water through the funnel into the tank until the water level reaches the "Max" fill line on the tank. Replace the cap.
  4. 4
    Inspect the microfiber cleaning pad if the steam mop is leaving water on the floor. If the microfiber pad is too wet, it will leave water on the floor. Unplug the mop from the wall outlet. Replace the microfiber cleaning pad. To replace the pad, move the latch strips out of the hooks on the mop head. Pull the pad off. Set the new cleaning pad on the mop head. Hook the latch strips onto the hooks on the mop head.
  5. 5
    Use distilled water if the steam mop is leaving white spots on the floor. Hard water may cause white spots to be left.
If none of the above work, then is it something that you purchased recently, and is new? If you did, then it could still be fixed under the manufacturer's warranty regardless of whether or not the original length of the warranty has expired. This could be due to the fact that you have received a product that has some sort of manufacturing fault, rather than it stop working through misuse by the user.
If it's a common problem, then you will more then likely be able to return it to the manufacturer and have it replaced for a new one, let alone repaired :-) - This only applies to whether or not the item is New though :-).
Hope this info helps
Apr 29, 2013 | Vacuums
I got power, lite on, tank is warm, but No Steam to mop pad, just a little water to wet the pad. Whats wrong?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Dec 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steammop doesn't work
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The heating element may have died or there is an obstruction...
heatman101
Jan 14, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Purchased Feb. '09 and has stopped steaming. Mop
heatman101
bt
Nov 02, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The shark mop just stopped working mid clean. The
It broke....
heatman101
Sep 25, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The unit produces steam but does not have the pressure to the cleaning pad. The water pump handle does not retract all the way either. Related?
No, probably two different problems...
heatman101
Jul 16, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Stopped steaming only releases water into pad
heatman101
ag
Mar 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Floor Cleaner streaking on pergo laminate floor
Start with a clean pad. A dirty pad wil spread the wet residue around and strek the pergo. After steaming use a clean microfiber dust mop to buff the pergo. It will dry and shine yur laminate.
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam mop won't steam
heatman101
zsd
Nov 16, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
380 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
