Question about Whirlpool Dishwashers
Mine dishwasher doesn't work on regular cycle only on light cycle, what is the problem?
    Habit-Forming:
  • 84 Answers
It sounds like you need the touch pad on your dishwasher
Posted on Sep 12, 2010
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Kenmore classic dishwasher washing cyle doesn't start
It sounds as if you need to replace the timer. The reset motor is separate from the primary motor--that is why one type of "cycle"--diagnostic-- seems to work but the regular cycle(s) do not.
Jan 30, 2013 | Dishwashers
Our dishes are not being cleaned well with residue left on plates and cutlery and the light next to the rise aid is on at the end of the wash
I have had the same problem a time or two. Make sure that you don't overload the dishwasher and nothing is blocking the spout where the water comes out. Also if you haven't done so already, you may want to add some detergent to the pre wash. Make sure you have enough detergent for the regular wash cycle also....Hottest water possible (at least 140 degrees F). If all that doesn't help, try cleaning them on heavy wash. Check to make sure the rinse aid level is still full. I have also found it easier if you rinse the dishes or cutlery off before putting them into the dishwasher.If none of the suggestions work I say changing your dishwashing detergent and/or rinse aid.Good Luck!
Sep 08, 2011 | Dishwashers
I need to know what the buttons say on the dishwasher. Mine have no letters
Some SHX46 washers have 4 wash cycle buttons and others have 5. The button on the left side on top of the door is the start/stop button regardless of how many wash cycle buttons you have.
If you have 5 cycle buttons, reading from left to right they will be as follows.
1. Top Rack Only / Sanitize
2. Power Scrub Plus - (Long wash for heavy soil)
3. Regular Wash - (Economy wash for light to medium soil)
4. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
5. Rinse & Hold.
These buttons are also used for cancelling a wash cycle. Hold down buttons 2 and 4 (Power Scrub Plus and Delicate) at the same time to cancel a wash cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration - from left to right - will be:
1. Power Scrub Plus - (Long wash for heavy soil)
2. Regular Wash - (Economy wash for light to medium soil)
3. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
4. Rinse & Hold.
With this button configuration, the cancel cycle buttons are 1 and 3.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Dec 12, 2010 | Bosch 24 in. SHX46B05 Stainless Steel...
I cannot figure out how to advance a cycle without having to go through the entire cycle. For example, I had a drain problem with my sink and the plumber put the rinse and hold cycle on for about 10...
Welcome to FixYa.
Your post doesn`t specify a model number, however on most Bosch dishwashers in order to change from "rinse & hold" to "regular" ( or any cycle ) simply turn the unit "on" and once the machine begins push the regular button twice.
Or the button applicable to the cycle you want.
That should change the display to look like this...
If this doesn`t work, try it for "econo" or any alternative and let me know how it goes.
Good luck.
Regards,
Macmarkus :)
Sep 03, 2010 | Bosch Dishwashers
My GE Adora dishwasher is not cleaning well and the detergent isn't completely disolving. What could be the problem?
Mine has been doing the same thing for about 2 months now.. I tried Finnish brand diswasher cleaner, but to no avail. Try this:
1) Empty your dishwasher, then take out the lower rack.
2) Start a regular cycle. Wait until you hear the jets turning, then open the door. Make sure there is enough water in the bottom - It should be just UNDER the heating element.
3) If your dishwasher is getting enough water, Reset your washer and allow it to drain.
4) Go to the store and get a gallon jug of white vinegar. Start your dishwasher on a regular cycle.
5) Once you hear the jets turning, Open the door and add FOUR CUPS (liquid measure) of white vinegar to the water in the bottom. Let the wash cycle complete.
6) When the wash cycle drains, the rinse cycle will fill. Once the rinse cycle starts, add ANOTHER FOUR CUPS of white vinegar to the first rinse cycle.
7) Allow the first rinse cycle to drain. Let the second rinse cycle complete normally.
I know this sounds too good to be true, but it REALLY DID work for me, this evening as a matter of fact! I also bought some hard water/soap film detergent additive from the store. It was kind of expensive, but I'm using it for a while just in case.
I hope this helps. Like I said, I couldnt believe it when my dishes came out clear again! Also, I turned OFF the heated dry cycle, and just opened the door and pulled out the racks when it was done.
Good Luck!
Mar 30, 2010 | GE Adora GHDA654LBG Dishwasher
Won't full cycle.
Ok. Mine has started working again somewhat. I ran a rinse cycle and the pump motor started working again. I then drained it, and started a regular cycle and it's working again for now. The motor still does not sound right though.
Mar 21, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Runs all the time
I just had this problem. I found an article that explained it and had the exact picture of my problem. It is http://fixitnow.com/wp/2006/06/09/bosch-dishwasher-takes-forever-to-complete-a-cycle/ .
I am watching my the dishwasher just move into the rinse cycle as I type this. My guess is that I just saved either $400 for a repair or $1000 on a new dishwasher. I think it is time for me to make a donation to that article's author.
Mar 18, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Help with dishwasher
What Brand is it?
Dec 31, 2007 | Dishwashers
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
