Question about Zebra LP 2844 Thermal Printer
Label not advancing to tear-off perforation
I have 4 x 6 label paper in my LP 2844, and the labels START at the precise position and FULLY print the label. However, the lable does not advance all the way to the tear-off point. (stopping short by about 1/4"). I am having to push the green button once and the label then feeds the rest of the way to the exact spot. What printer / driver setting might I need to change to force the label to print and then stop exactly at the tear-off position? Would great appreciate a solution to this!
  • 57 Answers
Try this to have the printer auto-sense the size of the labels:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
Posted on May 30, 2008
  • wilsey643 Jul 13, 2011
    This does nothing. I'm having the same problem as the person who posted this topic. My printer prints out the Out of DUMP blah blah, but right after that it still either feeds out 3 pages and stops half-way through a label, or feeds out half an inch at a time.
What media does the LP 2844 printer use? I have been supplied a roll of labels with-out any code on them. The printer seems to be working but does not print anything. The troubleshooting guide asks if I am...
Hi An Lp printer is a direct thermal printer.
That means that if you rub the label with your nail, you should see a dark scratch.
If you place a flame under the paper it should darken.
The head heat the paper at the positions where printing is performed
Jul 03, 2011 | Zebra LP 2844 Thermal Printer
I have Zebra LP 2844-Z printer and the barcodes
Here are 3 suggestions.
Check that your label size definition is correct, measure your label height in mm and check that your printer driver settings match.
Perform a calibration. How?? when printer is on labels loaded and green light, hold feed key and wait for 2 blinks then release feed key. (If you release it after 1 flash you will print a configuration label)
If you are using Zebra Designer, download latest version of Zdesigner V2. Install latest printer driver V2.63. This driver & Zdesigner allows you to calibrate the printer directly from within Zdesigner. Go to File/Printer settings/ advanced options and click calibrate at bottom of page. when printer calibrates then tick the box USE PRINTER SETTINGS and printer will now work properly.
Jul 01, 2010 | Zebra LP 2844-Z Thermal Label Printer
Zebra LP 2844 doesn't feed label all the way out for tearing off. When I print a label everything prints fine, however the last 1/4" or so is still left in the printer. Technically, it's like the printer...
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
May 06, 2010 | Zebra LP 2844 Thermal Printer
My lp2844 keeps printing part of the job on one label and the rest on the next. It seems like it starts the print job in the middle of the label and prints across ther perforation and onto the next label,...
sounds like you have the printer driver set to the wrong paper size
unfortunately some of these drivers disregard the settings you do in windows and so you need to set it twice , once in the windows printer dialog and second in the configuration wizard of the driver
hth hannes
Aug 29, 2009 | Zebra LP 2844 Thermal Printer
I use direct thermal paper with a black mark at
Compare the 2 rolls, Pay close attention to the position ans size of the black mark. The black mark sensor in the zebra 2844 is not (where you would expect it to be) in the centre of the label. It is about 10mm to the right,
Try calibrating the printer to your labels.
Check my other solutions to see how to perform a manual calibration.
Jul 29, 2009 | Zebra LP 2844 Thermal Printer
TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Dec 08, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 prints blanks
If the printer is printing nothing but blanks, try another roll of labels.
If the printer is printing blanks in between labels, it probably needs to be gap sensed. You can do this by:
1. turn the printer off.
2. hold the feed button down and then power the printer back on while still holding the feed button down.
3. release the feed button when the light flashes.
4. the printer will then regap itself
5. when the regapping is done, press the feed button once. It will print on the label that it is 'out of dump'
6. the printer should then be ready to go.
May 03, 2008 | Zebra LP 2844 Thermal Printer
Zebra lp 2844 thermal printer
It sounds like it needs to be re gapped. Try this:
the feed button.
Nov 30, 2007 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
1,037 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
