Te ELCB is tripped when you have a short. Since the actual parts appear ok (i hope you checked them for an internal short, they don't become live when you plug them in the mains) then the defect is in the wiring or the control panel: check every single wire or part (even the plug itself) for shorts to the ground / the case of the unit.
The heater element is by design leaky (it's basically a resistor encased in a capacitor, and the capacitors transmit alternating current) so that shouldn't be a surprise - even if the leak is important. But the motor/control leak is and it's a major malfunction - if you can't find the short and eliminate it then the unit is simply too dangerous to use.
Sorry i couldn't be of a more assistance. Please don't forget to rate my replies.
Thanks for that. No direct shorts found but leakage detected. Heater chassis to earth volts= 60; Motor/control unit chassis to earth voltage=100. Unable to measure current.I understand that heater elements always leak, and for that reason are sometimes connected to non-ECLB circuits, but other unit is a worry. Any further advice before I trash it will be appreciated.
Thanks again Azraelsrl, looks like the scrap heap!
I appreciate azraelsrl's solution - clear, concise, informative and very prompt.
