Question about Canon BubbleJet i320 Printer
Document doesn't print with new original ink cartridges comes out blank does the head need manual cleaning?
  • 1,476 Answers
Tigallant,
It would certainly not be a bad thing to do a manual cleaning. If this problem just started when the cartridges were replaced there are several possiblilities.
Now days inkjet cartridges are being refilled and sometimes sold as new units. My experience has been that sometimes they work and sometimes they don't. If manually cleaning the cartridges does not work I would return them to the store you purchased them from and exchange them for another set. I have never had a store turn me down on this.
If the next units do not work either I would go to Cannon's website at http://www.usa.canon.com/cusa/support where you can input your model number and download a new version of the driver for your printer. This may require a restart to install.
This should solve your problem.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Sep 12, 2010
Page not printing on Canon PIXMA MP750
That's as common as rocks with inkjets, especially if Copy doesn't produce visible output. Fortunately the clean cycle gets results pretty often. You need to heed the printer humidity spec. and follow the manual's further actions for when 'Clean Head' doesn't work (typically cleaning its bedding and/or running some rubbing alcohol through via a handy empty cartridge.) See your local ink refiller if you want a friend to lean on for cleaning cartridge fiddling.
Oct 22, 2011 | Canon PIXMA MP750 All-In-One InkJet...
I have try to print but its not printing. i've allready fill the ink still the page come out blank.
It could be due to the refilled cartridge that you are using. Refilled cartridges tend to degrade print quality and cartridge performance.
You can try to clean the cartridge nozzles. Please follow the steps below to fix the problem:
  1. On the printer control panel, press Copy.
  2. Press Options until Maintenance is highlighted.
  3. Press the right arrow until Align Cartridges or Clean Cartridges appears, and then press Select. A test page will then be printed forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the cartridges are working.
If that doesn't help, I would suggest you replace your cartridges with new genuine Lexmark cartridges.
Aug 17, 2011 | Lexmark X6150 All-In-One InkJet Printer
All the pages I print are blank. There is sufficient ink the print preview shows the image but the actual print out is blank
Sounds like your print heads are clogged. This is quite common. Go into your printer's menu and find the maintenance menu and follow the steps to clean your print heads. Run the process everal times until the prints are 100%. Then run a printhead alignment. Regardless of whether your not your ink is full, if cleaning the heads several times does not solve the issue, put new ink cartridges in because you may have bad cartridges. If that doesn't work, you've got bigger issues, contact the manufacturer.
Apr 26, 2011 | Office Equipment & Supplies
Printed photos have white vertical lines running throughout
Those are lines where the printer heads are not printing. Since in this printer the head is part of the cartridge you must clean the contact thoroughly, verify the data cable and replace the cartridges with original new ones.
If this doesn't fixes it then the defect is in the controller of the printer - the memory buffer that stores the image when it's received from the pc and sends it one line at the time to the printing heads . This cannot be repaired - the printer is dead.
Apr 17, 2011 | HP Photosmart C4580 All-in-One - InkJet...
I have a Dell 926 All-In-One InkJet Printer, I put a new black ink cartridge in the printer; still have plenty of color ink. When I have a document that I want to print from Word, it will sound like its...
Make sure you've removed the shipping tape from the cartridge's print head. More than likely the black cartridge is not disbursing ink - clean the print head carefully with "Q" tip and alcohol and see if black ink comes out slightly. Re-insert cartridge and try again. Perform "clean cartridge" in printer properties window.
Nov 03, 2010 | Dell 926 All-In-One InkJet Printer
Document is blank when print spooling and prints only blank pages. even test page printed is blank
I can only think its a problem with the ink cartridges.
Is it a new printer?
Have you taken the tabs off the ink cartridges?
Does it need a head clean?
Sep 04, 2010 | HP Computers & Internet
No ink on printed pages
Try to pull out the ink cartridges. Then after 1 minute put the cartridges on. Then it will initiate head cleaning. Just perform the head cleaning to clean clogged nozzles. Then try to print a test page.
May 10, 2010 | Brother MFC 490cw Color Inkjet...
Black ink won't print
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
Printer will not print ,paper comes out blank
Put new in cartridges in printer.
Page prints out blank.
Have cleaned the print heads 3 times.
Need help!
Nov 16, 2008 | Epson Stylus C66 Inkjet Printer
Color ink not printing
Ahhrgh! Don't use windex. It contains additives that can harm the printer head.
I suggested this site in another post and it could help you.
Sep 09, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Canon BubbleJet i320 Printer Logo
117 people viewed this question
old marine
old marine
