Question about Denon AVR-1908
Subwoofer attached to Denon AVR 1908 stops working. I was able to go in the manual setup and got it to work. This time nothing seems to make it work though the subwoofer is correctly connected.
4 Suggested Answers
  • 119 Answers
SOURCE: Denon AVR-987 System setup lockout
YOU NEED TO HAVE A MONITOR OUT CABLE FROM THE DENON COMPOSITE, S-VIDEO, COMPONENT OR HDMI TO AND UNUSED INPUT ON THE TV.
SELECT THAT INPUT ON THE TV AND PRESS THE SETUP BUTTON ON THE DENON REMOTE AND YOU SHOULD GET A VIDEO SIGNAL ON THE TV TO UNLOCK
Posted on Mar 03, 2009
SOURCE: subwoofer works in test mode on denon avr 790. but
I had the same problem. The system from the factory does not ship confgured for continuous subwoofer output. To fix this, do the following:
1. Enter the system menu.
2. Go to "Speaker Setup"
3. Select "Bass Setting"
4. Change the setting from "LFE" to "LFE+Main"
That should do it... You can also see this information in the "Bass Settings" section of the product manual on page 26.
Posted on May 04, 2010
markfreedman
  • 312 Answers
SOURCE: I recently purchased a new
Your sub-woofer apparently does not have an amplifier built into it. This type requires you to use your front left and front right speaker output to got through it to your regular speakers. It is called a passive sub-woofer for that reason.
To set it up, Connect your front speakers to the "output" of the sub. It should say "to speakers" on it.
Then connect the Speaker Outputs for the left front and right front on your Denon AVR-391 directly to the Sub. It should say on the back of the Sub "to amplifier".
Here is some theory you should know, if you don't already know it, that will help you get a satisfactory result in setting up this system.
There is a condition on setting up all speakers and subs that not everyone know. It's call "phase alignment". Phase alignment (A Good Thing) refers to all of the speakers in a system moving in the same direction (in and out) at the same instant in time. This gives you much clearer sound and better response from your sub-woofer.
Phase Cancellation (a bad thing) is when some of the speakers are moving out and other moving in during the very same instant in time. It causes problems in sound.
IN A SUB-WOOFER, IT CAN CANCEL OUT THE LOW NOTES.
Here is how to handle it:
On the back of the receiver the speaker terminal outputs are colored Red and Black. Black is considered negative and Red is considered positive. On the back of the Sub woofer and on the speakers the same colors apply. MAKE SURE THAT ALL OF THE CONNECTIONS GO BLACK TO BLACK AND RED TO RED WHEN CONNECTING UP THE SPEAKER WIRES.
The system will work either way. But you will have severe bass loss if the woofer wiring is out of phase because of phase cancellation.
Hope this helps,
Best Regards,
Mark
"Phase Cancellation"
Posted on Jan 05, 2011
Problem denon avr 1910
most electrical units have a fuse inside,try taking cover off and checking for blown fuse,or,take it to radio repair shop.My Harmon Kardon stopped after 3 years,and the report said the unit that failed was quite a common problem for the modern multi channel amps,quite cheap to fix..All my tips are free
Jul 04, 2010 | Denon AVR-1908
Denon AVR-1908 speaker issue
Before we play taps and throw dirt on top of the Denon, perhaps a bit more triage is in order. I'm not certain who the patient is. Especially when you have "speaker issue" in the title. Are you saying there are some speakers that don't work ONLY with BluRay?
If it has NEVER worked the (unnamed) BD player or its cable(s) could be at fault, too.
What 'connections' are we talking about. HDMI, coaxial- or optical audio, 5.1 analog; to what input on the Denon assigned to what function?
Have you tried all audio paths out of the BD player? Is it configured to squawk in the right digital mode?
Do you have any other digital audio sources (CD/DVD) you could use to certify the audio paths that don't work with the BD player?
Apr 08, 2010 | Denon AVR-1908
Flickering video with Denon AVR 1910
I had the same issue with my Denon AVR-1908.....It turned out to be the cable box, not the receiver. I would suggest you unplug your cable box, remove and reseat the cable card,HDMI cables, and finally the cable line itself. Make sure the wires are not frayed or otherwise pinched.
Good luck....
Mar 05, 2010 | Denon AVR-1908
While watching tv my speakers started cracking and went loud then just stop working. turn the unit off then back on it works for a few seconds then does the same thing.Denon AVR 1908
I had the same issue..I called Denon support and they fixed the problem. You need to reboot the micro-processor....turn off the unit...hold down A+B then turn on...the display blinks (all the display is illuminated) Let go of the buttons.....issue resolved!
Good luck....
Jan 08, 2010 | Denon AVR-1908
Tuner not working.
These do on occasion have a bad fm tuner assembly. part number 9630145608. to verify try a fm ant to see if works
Dec 09, 2009 | Denon AVR-1908
Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Aug 20, 2009 | Denon AVR-1908
I have Harman Kardon speakers and subwoofers connected to a Denon AVr 1508 receiver. All my five speakers are working but my subwoofer doesnt work. I m pretty sure I have connected the subwoofer properly...
There is a setting under your speaker setup to turn the subwoofer on. If speakers are set to small it auto matically sets the subwoofer to ON. If the speakers are set to large it turns the subwoofer off but you can manually adjust.
May 02, 2008 | Denon AVR-1506 Receiver
Denon AVR-1908 Logo
124 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
