Question about RIM BlackBerry Bold 9700 Smartphone
Can someone help me..when i on my hp i encounter error msguncaught exception:net.rim.device.api.i18n.MissingResourceException what shld i do
  • 70 Answers
Can you re write this, i dont fully understand it
Posted on Nov 02, 2010
Error code d04-560 displayed. how do i clear the error code?
HP Tech Support Number is contact number to call a certified technician and get online solution for HP devices like HP desktop computers, laptops, printers, scanners and tablets showing a technical problem at the time of use. This is a 24-hour available personalize help service for HP users in US, Canada and other countries to help them when they encountered technical errors.
HP Support Phone Number 1 (888) 687-4491 can troubleshoot critical problems like operating system issues on HP, software problem, driver issues, wireless connectivity problem, antivirus issues, virus scanning problem, malware removal error, adware problem, HP system running slow, printer connection problem, data backup and other technical issues affecting the HP computer and other devices.
Mar 14, 2018 | The Office Equipment & Supplies
What could be problem
The first problem I encounter, is I can't read minds. I only can help if someone can describe here what the error is they encounter.
In a question it is great to enter the device name, brand, model and year of production. Then describe what you don't get, what you were expecting and since when.
Perhaps if you can share the problem this way someone here on foxy can help.
Jan 13, 2015 | Cars & Trucks
Twain driver for hp scanjet G2710
I just wonder how to choose the right twain scanning API for the scanner. By the way, you can ask your question at HP support forum, also, like
http://h30499.www3.hp.com/t5/Scanners-Experts-Online-Now/64-bit-Twain-driver-for-HP-ScanJet-G2710/td-p/2337525#.U3k8IHYoZ2M
VB NET TWAIN TWAIN Scanning Using VB NET
Jan 18, 2012 | HP Scanjet G2710 Flatbed Scanner
Uncaught exception index15>=15 and followed
The error 523 means the system process had died and a jarva process has terminated, and the device can not continue to operate in a normal manner.
You need to wipe the device and update the software.
Hope this helps
Feb 11, 2011 | RIM BlackBerry Curve 8520 Smartphone
Can't get documents to go files to work says "net.rim.device.api.ui.text.breaklterator not found."
Hi, some files are missing(has been deleted,.
To restore reset the phone . how,
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Aug 16, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Describe your Uncaught exception java lang
I need to know how to reset or wipe clean because i cant get jpast this message at all uncaught exception:java.lang.nullpointerexception i cant do anything help
Dec 12, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Webpage error detailsUser Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; SIMBAR
User Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; MAAU; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; MAAU)
Timestamp: Wed, 21 Jul 2010 17:11:22 UTC
Message: Type mismatch.
Line: 179
Char: 1283
Code: 0
URI: http://api.msappspace.com/apprendering/152296/profile.right/07212010083001/1_0_0/render.app
Line: 179
Char: 1283
Code: 0
Message: Object doesn't support this property or method
Line: 279
Char: 17
Code: 0
URI: http://api.msappspace.com/apprendering/108417/profile.right/07212010080001/1_0_0/render.app
Line: 298
Char: 17
Code: 0
Oct 21, 2009 | Microsoft Internet Explorer 8
Blackberry 7290
for that problem you should re-install the blackberry system for your pda and it would work! good luck!
May 13, 2008 | RIM BlackBerry 7290
Blackberry Pearl problem.....
same problem, me too. no answer.
Mar 16, 2008 | RIM BlackBerry Pearl 8100
Magicolor 2400w Bad print quality and white lines
The solution for the white line problem in the 2400W is to clean the laser lens.
Take out the drum and wipe the laser lens with a soft clean cloth.
Replace drum and carry on.
I had to do it twice before I removed the speck of dirt that was causing this.
Wendy
Feb 21, 2008 | Minolta 2430DL Color Laser Printer
RIM BlackBerry Bold 9700 Smartphone Logo
44 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
